Hi to all in this forum, I just took my 1968 Chrysler 55hp out on the water today....As soon as i started it, the gas seemed like it was stuck and revving really high!...so i shut it off, checked things over, started it again...the idle was normal...I go to shift it in gear and it runs fine then all of a sudden the rpms go up high stay high, I put it in neutral and still revving high...shut it off turned it back on still running high. There was three foot waves on the water as well, which I don't think this would have anything to do with how high my engine is revving.
I would like to add that before winter I rebuilt the carb and replaced the float...I set the float to the correct specs...have the air screw on top set to 1+1/8 turn out...also a new needle and seat...I am stumped as to what the problem could be...Someone said that it might be the linkage or synchronization is out of adjustment...i've been trying to mess with idle screw on the tower but no cigar....Would could cause the high revs and the revs staying high???
Any help at all would be very appreciated since my last resort would be to bring to a boat mechanic...I do have a manual for this old Chrysler as well....
Thanks
Rob
Thanks
Rob
