68 Offshore restoration
Sharpie223
The prescribed method for flattening when using it as the intended lawn edging is to lay it out in the sun. I plan to speed things up with a heat gun. It should be as stable as any hdpe or uhmw that we use elsewhere on our boats.
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Thats a pretty cool use for that material. Will be interested to see how it works out.
My kayak is made with hdpe, and the newer formulas can pretty much be reused indefinitely. I fixed a hole in my kayak by "welding" it with melted hdpe plastic, sanded smooth, and shined it back up with the heat gun. So that stuff is also indestructible. Awesome what you did with it, thinking outside the box.
Sharpie223
It's probably more work than patching with epoxy and aluminum on the underside. I think it will be easier to look good, though. Also, my thought is that the plastic should be less likely to burn skin in the summer.
Sharpie223
Using this weekend to try and paint the sides. Removed the registration stickers, adhesive remnants, sanded and tacked today.
The registration numbers were easiest with a heat gun and scraper, but my mind wasn't in the zone initially, so I ended up making a mess on one side with a wire wheel and acetone before thinking of it.
For tacking, I tried acetone but that turned the dust into a smeared mess, xylene worked well to clean the surface but not melt it. Alcohol would play nicer with the breathing space but I didn't have any on hand right now.
Tomorrow I will mask and then prime with u-pol epoxy primer. Focus will be bare spots, but I have enough to cover quite a bit. I would have preferred to prime today immediately following sanding the bare spots, but time constraints prevented that. I think it should still be a suitable surface tomorrow. Sunday I will roll on a 2k polyurethane gloss black base, then spray a sky blue metallic flake streak, and silver Starcraft lettering.
Sharpie223
When I paint, it often doesn't go as planned. Today was no exception. The constant breeze made masking a bit of a paint, since I was using cardboard to cover large spans. I should have pre planned masking plastic. The base black layer painted fine, though it was taking longer to harden to the touch than I'm used to. I needed to get it done today or it wouldn't get done so I forged ahead with masking for the starcraft logo. That mostly went fine but I think it would have been better to paint the letter color first and then mask off the letters that the other way around. The way I did it the stencil had a few structural issues while applying. Then I masked for a flake stripe. I had to move cardboard up for this. Middle of the flake job it started to drop and I got a bit of overspray where I wanted plain black. I have enough touchup black to fix that, but not if I kept painting, so I had to stop with an uneven flake coating. I don't love it, but I'll live with it. The picture looks worse than in the sun in real life. Still way better than faded pale yellow. Now I have masking sticking to the base black and causing marring when it does lift. I'll have to touch up that as well.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
We all are our own biggest critics. No body but you will notice. Looks like good progress from here.
SHSU
Sharpie223
The uneven flake looks less noticible in sunlight, but the overspray where I had masking failure will need to be fixed. I would have sprayed a heavier layer of flake to even it out if the masking hadn't failed. My masking on the black did leave some impressions and pulled paint in several spots. Apparently I should have done the black a day in advance so it was more cured. I'll be touching up any spots that masking removed, flake overspray, and hopefully masking impressions. Then it will look a lot better. I may even consider a layer of clear coat to help even out any surface texture differences. Worst case, I get tired of it later on and add another layer of paint like so many other boats out there.
There is a good reason why I did the boat first and not my car.
Sharpie223
After working to remove the last of the masking, I touched up by the light of an electric lantern last night. Here's how it looks now. Some brush marks up close, but looks good (enough) from a distance. I was going to go with red flake for the longest time, but driving around over Easter weekend, I saw a lot of boats with that scheme and decided it was over done. This was Didspade brand. 008" sky blue. I think it looks more aqua/teal, I think I generally like it better than red anyway. Now I need to change my fender colors.
Sharpie223
Got slightly more planking done today. Hopefully the opposite side is symmetrical enough that I can use the first as a template.
Sharpie223
Finished one half. I wanted to use it as a template for the other side, but my boat just isn't that symmetrical. The edges aren't the most accurate with the guess, hack, and check, so I'm thinking about if there's any kind of viable trim to cover it. Otherwise I will paint the aluminum first so the difference is less noticible.
SHSU
I vote for painting with a little brown paint and calling it good. If we tried to hide every imperfection we would never finish our boats.
SHSU
Sharpie223
I think I will need to go a different way than the hdpe. Last night I finished cutting and put the temporary screws in place. It looked great then and I was able to pull it all flat. This morning it is very warped, wrinkled really. The aluminum is just going to expand/contract too much for it to stay flat. At this point I'll likely just countersink the unwanted holes a little and patch with an appropriate epoxy putty, then paint the top. It looks much worse in real life than the pictures show. I was going to trim the top edge of the open bow this way, but now I will probably recreate the original vinyl trim, maybe without the upholstery foam.
Moserkr
May I suggest looking into hydroturf? It could be held down nicely under the trim pieces, and its glued down to the gunnel top as well. Very durable, sharp looking, not overly expensive. Would cover up any holes too. I used it for the flooring of my boat instead of a vinyl or carpet. Was going to do the gunnels but the Admiral shot it down. Lots of colors and patterns to choose from too. I get the off brand type from the online jungle store.
Moserkr
I hadn't thought about that. Its just EVA foam, right? I'll see what that will cost.
Yup closed cell eva foam. I got the teak color, its kinda golden with black stripes. Should cost you around $120 to do it is my guess. If guys can use it in duck boats, its gotta be durable. Love walking on it, super comfortable. Does not get hot.
Sharpie223
Yeah, so the stuff made specifically for boats is a little spendy, but then I remembered that harbor freight has an EVA anti fatigue mat, grey, with a diamond plate pattern. $11 for a 6'x2' chunk it looks like, vs $60 for an 8x4 roll of the flooring, so maybe half the price. I think I'll go get 3 mats to do this. The foam should be cooler to the touch when baking in the sun than aluminum or hdpe. I'll probably use this for trimming the bow opening as well.
Sharpie223
I bought 3 rolls of eva anti fatigue mat. It's thicker than I want but should be a good non slip surface if needed, and stay cooler than other materials. Lowes had some vinyl grey diamon plate made for garages, only 1/16 thick, but I've been on boats where you can't touch the edges in the summer, so decided against it. I also got a tach/hour/cylinder head temp gauge and gps speedometer on order. All that said, #3 came this last weekend so progress is on pause for awhile.
SHSU
If I read that last part correct,
Congrats!!!! A new Admiral in the family just bumps up the need to finish the project to spend time as a family. Nicely done sir
SHSU
Sharpie223
Weekend update:
I installed my digital tach/cylinder heat temp gauge, the wires were too short to run from outboard to dash, luckily the temp sensor is an rtd, not a thermocouple, so I was able to splice in extension wires. I mounted my floor locker with hinges, I'll probably change the trim from 3/4 beveled wood to 3/16 aluminum or similar when I start working on it again. I'll leave the seat covers and drawers uninstalled for now, they aren't urgent. I emptied last years gas into my car to dilute and burn off, then ran some fresh gas with concentrated seafoam and injector/carb cleaner through the engine. There is an issue where it will idle for awhile and shut off. It restarts right away and with how long it can run, I don't think it is a fuel pump/choked flow problem. My best guess is some air possibly getting in through a loose connection. Once that's fixed, I'm going to run as is for the season so I can actually fish.
Next winters work:
-I decided the center opening in the bow doesn't matter to me, so I will make a solid platform there that runs to the back of the console sides. I think this will simplify bow storage as well.
-I have a plexiglass pane to make a windshield center, but am now thinking I will just replace the whole windshield with something custom. I'd like to use tempered glass but I may cheap out and stick with plexi. The plan will be to make an angle aluminum frame, probably windshield wipers if I go with glass. Seriously contemplating getting a tig welder for the aluminum work I want to do.
-finish drawers/seat covers/locks and latches.
-I will likely paint my gunnel, thinking durabak. I think long term I won't be happy with foam.
-remake dash, give it a decorative face, make a glove box for the passenger side
Things that will slowly happen this summer:
-better anchor mount/possible caddy
-trailer mods
-better lighting and battery switch
