Hi,
My 6HP 1968 Johnson will not idle, and intermittently runs rough and misfires, and is pretty intermittent at starting. As far as I know I've eliminated any fuel pump / carburettor issues - largely through help from this forum. The idle jet is clear with no air leaks.
With plenty of revs it is pretty stable, but invariably, as soon as the power drops off it just starts suddenly losing revs, then suddenly gaining revs, and at idle speed it seems to want to idle, but just can't sustain it - as I say, I'm convinced the slow speed fuel flow is fine. At times I'm sure it's only running on one cylinder. At other times it runs ok for a while at medium / low revs but will invariably cut out eventually.
I did a compression test and it's not too bad - 90 in one and 78 in the other cylinder, which is just outside what is generally thought to be ok i.e. +/- 10 psi, but obviously pretty close. I did find out today that it has the wrong sparkplugs, and have ordered a replacement set, but there is a spark from both. Don't know if that could be the issue, but I suspect it's more than just that.
Any ideas? I'm thinking it could be ignition but don't really know where to start. I've ordered a flywheel puller either way!
