7.4 alternator ?
ericcarr2000
Ensign
I will be replacing the stock alternator on my 290 7.4 motor. My question is will a standard 1 wire alternator do the job? I just want to ask before having to climb into the engine compartment is all.
alldodge
So long as you don't have an isolator or ACR in line between the output of the ALT and the battery.
Now for the three wires you won't be using. One is black and that's just a ground, one is red/purple and the other is purple. Both wires have 12V on them when the engine is running, Red/purple (all the time) and Purple when running.
My opinion, I would not change it
Edit: not change
ericcarr2000
Ensign
Ok, I guess I'm asking is will I be safe if I order a 1 wire alternator or what kind do I need to?
bruceb58
Why would you buy a one wire alternator when a 3 wire is actually better?
And why are you replacing your alternator? Is it not working?
ericcarr2000
Ensign
I'm repowering her with a mildly built 454 and was thinking of just replacing it with a nice chrome one. I can't remember if the one that's on there now is a 1 or 3 wire though.
alldodge
Just realized I left the "not" out of my prior post. I would not change to a one wire. You should have a three wire currently installed
alldodge
Standard 65 amp is all you need unless your going to put in a mega stereo system and lights with several batteries
bruceb58
Agreed, what are you operating that you need a bigger alternator?
ericcarr2000
Ensign
Nothing really, I just have the 2 batteries. 1 for the deep cell battery and the other one for the lights & such stuff.
bruceb58
Just keep your present alternator then. Spend the money on an ACR.
alldodge
What's a acr?
Automatic charge relay, turns on when the engine is running to charge both batteries. This or an isolator will do pretty much the same thing (OK the ACR is better by .10V).
My opinion, just keep what you have and do nothing
bruceb58
ACRs are also smart so that you aren't charging a battery that has failed so that your good battery continues to get charged. I have ACRs on both my boats and on past boats.
Diode isolators have voltage drops from around 0.4V to 0.7V. Only way to get around that is to remote sense on one of the batteries.
https://www.bluesea.com/products/761...12_24V_DC_120A
