7.4 MPI intermittently hard to start/rough idle
Status
Not open for further replies.
Mischief Managed
Re: 7.4 MPI intermittently hard to start/rough idle
Tested continuity from the DLC to the ECM connector, it's good. Scratching my head...
tpenfield
I sent you an email . . . not sure if it helps.
Going to get my place in the line of traffic now.
Mischief Managed
I got the email Ted, thanks. I already have the manual printed and in a binder though.
Mischief Managed
My manual states that the DLC connector B pin should be connected to ECM connector J1 pin 7. As near as I can tell, it's connected to J1 pin 23. No matter how I count, There does not seem to be any way the it's connected to pin 7. Does anyone have a diagram of the J1 connector showing how the pin count works?
If DLC B is indeed supposed to be connected to J1 7 and is not, I can see how this would prevent my ECM from going into diagnostic mode.
Mischief Managed
Disregard my request for a diagram above, I found it on page 5C-29.
tpenfield
Seems weird that the wiring is not matching up to the manual & schematic . . .
Are you still managing to do some boating this weekend, or has the engine hatch been up so far. ???
Mischief Managed
So now that I found a connector diagram, I took a look at my J1 connector and it has a completely different wiring configuration than Service Manual 16, 1996 edition describes. I guess they changed the wiring between the publication of the manual and the manufacture of my engine, or I am missing something key. I think I'll take it to a shop if it happens again; I don't think I can justify the cost of a scan tool/Rinda software-cable...
Boat is running perfectly right now. Will be taking it to Maine for the weekend later today.
Don S
Probably because it's the wrong manual. You should be looking in Service Manual #23
After you download it, go to page 5E-40 and see if that works better.
Mischief Managed
Thanks Don, that's perfect!
Ran the boat all weekend for water sports etc. and it always started and ran perfectly. I did put 30 gallons for fresh gas in the tank, cleaned the throttle body, and R&Rd the fuel filter to make sure it was sealing well; perhaps one of those things fixed it??? Planning to take it on the Gulf of Maine for 100+ mile day cruise next week, fingers are crossed that it does not strand me...
warsaun86
Don, I have seen that you are an expert with Volvo Penta engines and I have been facing a problem for the past 3 years and gone through 4 engines and thousands of dollars with mechanics and with my most recent engine I am still facing my original problem. After running about an hour my Engine starts to lose power . . . I usually try to run around 3000 RPM however if I run WOT the engine will lose power faster. I broke down and bought the diacom marine diagnostics tool and am trying to tackle the issue myself. Below is a link to the engine readouts and the engine bogging down after over an hour of use, you can see it jumping between 3500-3000 causing it to jerk back and forth . . . I'm hoping maybe you will see something out of wack based on the reading I am getting (no trouble codes). Thanks for your help!!
https://www.youtube.com/watch?v=tS2IY1NCfB8
warsaun86
I should also state that my engine is also a 7.4 MPI but it is a Volvo Penta 7.4 Gipbycce
GA_Boater
Don is looking down at us. RIP.
Closed.
Status
