Hi. I have a 2000 mercruiser 7.4l mpi s/n 0M023416 with bravo 1 drive. 120 hours on it. It has steadily lost power to the point it will no longer get on plane. It starts ok. Idles ok. But you can tell it's rough. There appears to be no change when cylinders 6,8 plug wires are pulled from the distributor cap. While any other cylinder disconnected makes it run worse.
I have done the typical first things. Changed cap,rotor,wires,plugs and filters.
When I removed the old plugs cylinders 6,8 they were black and appeared oil fouled. After a test run I checked all the plugs again. 6,8 were now perfectly clean. All others looked good. i swapped the spark plugs around. the plugs looked ok. No change in how they looked running in 2,4. I expected them to come out clean. Thinking they were getting steamed from water intrusion.
All cylinders are getting spark. Compression test was good. 135-145 lbs. It was done with engine at running temp. All plugs removed. Throttle open.
Fuel pressure tests were also good. 39-40 lbs idle and ok on test run under load.
I'm at a loss as to what's wrong. Any ideas to point me in the next direction?
Will a new spark plug remain looking brand new if the cylinders are not getting fuel? Maybe injectors?
Thank you.
Thank you.
