7.4L Impeller replacement attempt
Keeb Moving
I seem to have more water coming from the Starboard engine than the port and the pet engine is running slightly over 180 degrees. Starboard runs just over 140. Risers are inspected and in good shape.
Question: could this be caused by impeller installation with fins in wrong direction?
tpenfield
The impeller will not turn if the vanes are facing the wrong way . . . BTDT. So, probably not the cause. Look elsewhere for coolant flow issues.
San_Diego_SeaRay
I just had an overheat issue to 225 degrees. I had gone through 4 impellers. Turned out to be the impeller housing. I know you've done enough work but if I were you I'd pull that port impeller housing and check closely for grooves in the walls and cracks in the inflow and outflow ports; those are hard to see.
After replacing my housing my engine runs at about 125 degrees and I have a hard time getting it up to temp, which is *another* issue (probably thermostat). But it certainly won't be getting to 225 degrees any time soon.
Keeb Moving
Impeller housing is new. Thermostat is new. Would a chemical flush like barnacle buster make a difference? I’ve flushed all heat exchangers with water, looking for impeller peices and they appear OK. I have a closed system.
San_Diego_SeaRay
I'm not familiar w. closed cooling systems; never owned one. Although I *should*.
But a boat mechanic once showed me a trick that might be useful to you especially since you have two engines and one operates well. You need to find exactly where the raw water enters the cooling system. I've attached a schematic and indicated where it would be on the schematic, but you need to find where that would be on *your* system. You then detach the hose at that point and run each engine for an *exact* amount of time, I'd say 30 seconds to 1 minute. You empty that hose into a bucket. You need to be careful here because there are a bunch of belts and pulleys that may really make you regret buying a boat. After you do this with both engines, you compare the volumes. The amount coming out of those hoses should be just more than a regular garden hose. If the amount that comes out of the bad engine is significantly less than the good engine, then that's a pretty good sign that you have a problem *downstream* from that point. Since you have a new housing and impeller and you cleared the system previously then as Scott Danforth indicated, Bravoitis might be a culprit.
If both volumes are the same, then I can't really help diagnose a closed system but at least you can be confident you've begun to isolate the issue as upstream from that point.
