7.4l Mpi Mercury
J.D. Mac
I Have A Mercury Mie 7.4l Mpi 2001 . My Question Is Has Anybody Had Experience With Oil Comsumption With One Of These Engines. I Have No Dtcs , No Blow By And All Engine Parameters Are In The Normal Window Of Operation. The #s Match The Stbd Engine That Is Not Consuming Oil. There Is No Prefomance Issues Either
Help Please
Jdm
Bt Doctur
Re: 7.4l Mpi Mercury
With no external leaks , good compression readings,I`d suspect the valve stem seals.
Ayuh,... What kinda Consumption are We talking,..??
Where's it Going,..?? It should be leaving a trail somewhere....
Frost cracked oil cooler maybe,..??
J.D. Mac
Thanks for the input, valve seals was my thought aswell, I do not know if Mercury put positive valve seals on the exhaust valves. I know GM did not form 1989 on . Does any buddy know ? The lack of blow by tells me the rings/cylinders are OK. A compression test on the inboard bank will be VERYtime consuming & expensive
Thanks
Don S
Just an FYI
Mercury is the outboard part of Mercury marine.
Mercruiser is the Inboard and IO part of Mercury marine.
You have a 7.4 Mercruiser MIE
PS: Check your PM's (Private Messages) Upper right where it says Welcome JD Mac.
zbnutcase
A friend of mine had a Suburban with the same prob and it was a valve guide issue. 'nutcase
