Str8OutTha9c
- Sep 23, 2008
- 41
I recently purchased a 7.5 Sears Ted Williams a couple day ago. The guy started it up for me before I purchased it. It turned on and ran for a bit but it was revving at a high RPM. Is there anyway to lower this? And also, the spring on the pull start cracked, so I have to manually rewind the rope back in. He told me that he recently replaced the water pump on the motor, and he said that there's some sort of bilge pump built in also with a hose that goes into the back of the boat that will drain any water that has leaked into the boat. The motor turns on but shuts back off after a little while, unless the bulb is pumped manually. Could this be a fuel pump problem? I would like to get this motor going so I can take it for a spin. I have read that these motors are pretty fast.
Here's a pic of the motor on my jon boat.
