rolmops
- Feb 24, 2002
- 5,704
Hello guys.
This evening I was trying to drop the lower unit on a 1979 long shaft 70 horse Johnson.I disconnected the shift rod next to the engine and took out the 4 bolts on the side ,the one bolt toward the rear and the bolt that sits under the trim tab.Everything seems to be loose but it does only go down a little and stops although it seems quite free.It looks like it hangs up on the the shift rod.Is there a trick having to do with the shift rod that I am unaware of?
thanks for your help.
