I have a 70hp Chrysler model 707HF apparently built somewhere in the '70-'73 range. I had it running beautifully, but left the gas tank vent open because of the heat, and guess what, it rained! Water in the gas and carbs now. Drained the tank, cleaned the bowls, strainer, and line. Then lost fire. Cleaned the plugs, cap contacts, and points to no avail. Had to replace the power pack. Now it still won't start, but at least it will backfire now. I'm thinking there may be some gunk still in the carbs or the points are opening too far. What is the correct setting for the points gap? It's been so long since I had to set them, I forgot.
Any other help or suggestions will be appreciated. Thanks, Don.
