70 hp Johnson Starter problem...DRIVING ME CRAZY!
gaf11123
I've got a 1989 Johnson 70 hp motor I just bought. I got it converted over to a tiller control today. When I hooked up the battery and tried to start it, the starter is dragging bad and will barely turn over the motor. A couple of times it turned over better but way to slow to fire it up. I have used 3 27 series batteries that are all charged up and work fine. My question is I didn't get any cables to hook up the starter to engine so I picked up a set of 8 guage wire jumper cables and used them. I put 4 guage connectors on the ends. Could these cables be my problem? I felt the positive cable and it was warm a bit after just 5-6 seconds of trying to start the engine. I took the starter apart tonight and cleaned the starter good. All the brushes looked real clean and good. the rest of the internal parts also seemed fine. Any ideas here? Man I worked like heck to get the tiller situations working ok as there never was a 70 hp tiller. I got it working great, now something else to hold me up. I want to go fishing next week. On vacation and would appreciate your ideas and advice. Txs again Glynn:)
62 ROYAL SCOTT
Re: 70 hp Johnson Starter problem...DRIVING ME CRAZY!
hey gaf it may be your cables check all your connect's and you say the brushes look good, maybe the timeing is off that's only other thing i can think of that would make it drag
Haffiman
If cables are getting hot, it is a sign of either a short, or at least more Amps are pulled through the cables than what they are able to handle.
I would suspect 8 Gauge wire to be far to thin for battery-starter wires, unless they are of space quality and super conductive!
Change to around 2-4, but it might even depend of the cable length from engine to battery.
