70 hp power trim motor replacement
mikenjo
i have a 1992 70hp evinrude and the power trim motor went. does the engine need to be removed to replace it, any hints on replacing it
mikenjo
Re: 70 hp power trim motor replacement
any info would be great before i tackle this repair
mrcj001
You should be able to remove the trim/pump assembly. Take the motor to a electrical repair shop and have it tested. Its either worn brushes or a overload curcuit thats bad. If its the overload curcuit thats bad , have the tech to by-pass it and put a 20 amp fuse between the motor and the battery.
Cheeper than buying a new one.............
