703 remote control- wiring
bigbrownbuku
Master Chief Petty Officer
Re: 703 remote control- wiring
likely you have a push to choke ignition switch. the 703 is very versatile, if your engine doesnt have/need a manual choke disregard it.
bigbrownbuku
2 double posts in 2 days, methinks the board is having a coniption.
dittyp01
Originally posted by BenC:<br /> likely you have a push to choke ignition switch. the 703 is very versatile, if your engine doesnt have/need a manual choke disregard it.
dittyp01
Originally posted by BenC:<br />[QB] likely you have a push to choke ignition switch. the 703 is very versatile, if your engine doesnt have/need a manual choke disregard it. <br /><br />I received a new yamaha ignition switch from a friend. It did not have a blue wire but the<br />yellow wire had 3 connectors on it. Does the <br />choke shut off automatic.I plugged the blue wire<br />into the extra yellow connector. the motor starts and runs normal. will this cause damage?<br />is the choke working? <br />it
bigbrownbuku
/me rubs crystal ball...damn too cloudy.<br />whats your engine model?<br />just leave the blue wire unplugged if your engine starts.
