You should be using a 140F thermostat. 160F is considered overheating.
I ordered the 140F thermostat and that's what I have installed.
Is the bypass located in the head or behind it? I have tried to look but can't figure out where it is.Well, the issue seems somehow to be related to the t.stat - the device itself or installation. I don't recall if you tested it to see if it is operating correctly, but it's new.
If it were mine, I think I would run without the t.stat for a bit -- see what the operating temps are. If in a lower, safer range, test the t.stat, check installation instructions, and have at it again.
[Edit. Noticed I made a dumb mistake up in #6 -- water pump on the mind, but meant to refer to a bypass in the t.stat housing. Check and see if that is blocked at some point. Doesn't connect exactly with your symptoms, but worth checking.]
[...that's backflushing.] auto-correct....
I would try another IR gun and compare IR readings, just to be sure. Dash gauge is suspect (high) -- may be a sender issue.
