70's Chrysler 130 hp
tgp***
I have an opportunity to buy a mid to early 70's 130 hp Chrysler (w/ t&t and controls) outboard for my 1972 18 foot aluminum boat I'm rehabbing.. Personally I'm not knowledgeable about Chryslers at all. Owner says it runs, and he ran it last fall. His boat was junk and he's putting the motor up for sale. He said it has points and distributor so if the box went bad I could always put in a coil and something else to run it.
Any insight on what to look for will be appreciated. Also, is there a Chrysler web site that will tell me what serial numbers are for what year.
Thanks
Frank Acampora
Re: 70's Chrysler 130 hp
First three photos are of old style (up to 1978) gearcases. last two are post 1978 engines.
Distributor with points would be early to mid 70s. The owner is correct: iIf the Motorola CD ignition box fails, it can be replaced with a standard coil with just minor wiring changes.
While there is nothing basically wrong with these engines, and while I am a die-hard Chrysler fan, because of their age I stay away from them. They are a difficult resale. I prefer the late 70s-early 80s Chryslers. They have a cleaner design and simply look a bit better.
Props, while still available on ebay are not available from any current manufacturer. Additionally, the props are spline drive with a thrust pin and I never liked that arrangement.
Later Chryslers--after 1978 had a much better lower unit and props are still available--in fact some Mercury props will fit.
The engine block was continued into the Force line with only minor changes so most parts are still available with a little searching.
Power trim and tilt will be "iffy." It is the old three wire motor and probably the old style pump. The internal "O" rings may be at the end of their life. They may last but may also fail almost immediately. First indication will be that the engine will "bleed down" and not stay in a tilted position. However, power tilt/trim units from any 85-140 up to 1990 will retro fit to this engine. The mounting rode do tend to correde into the engine aluminum and become difficult to impossible to remove.
On the plus side, it is a dirt simple engine and easy to work on. No special tools other than a torque wrench, timing light, and a flywheel puller (steering wheel or harmonic balacer puller) are necessary.
Unless you get a really good deal, or if you want it for a period correct engine, you might want to think twice about it.
tgp***
Thanks for the reply.
Looks like an earlier model. $350 is what he's asking for it. A period motor would be nice but not necessary. I have 65 hp motor I could put on it but not sure its big enough. I have a 2nd 65 hp on a 16' aluminum runabout and that runs out at about 32 to 34 mph on paddle wheel speedo. This 18' footer just seems like a much bigger boat.
130 HP OUTBOARD!!!
Frank Acampora
350 is about right. After all, it does have power trim and controls. It looks relatively clean in the photo and yes, it is earlier than mid 70s probably '73 or '74. If I were buying it, I would do so with the understanding that it is an unknown engine with no history--they all ran when taken off the boat or put in starage. So before I actually bought it I would check compression the cheap and dirty way. Put my thumb over each plug hole and turn the flywheel by hand. If it blows my thumb off the hole, at least I know that there is no major piston damage. Then, before actually using it I would set everything back to factory specs and change lowwer unit lube and water pump impeller.
Nordin
Looking at the cowldecals it is a 1971, 72 or 73. 1970 the background of "CHRYSLER" were white and the # were blue instead of red.
1974 the background were black and "CHRYSLER" crome, the # background red and # crome.
Check the serialnumber and we can give you the year.
jerryjerry05
130 on an aluminum boat??? What's the boat rated for??
Hate to see you rip the transom out???
tgp***
Rated for 140. 18' Holiday O.B.
[/IMG]
jerryjerry05
Kool!!
My fishing buddy has a 17 alum. and wanted to put a 125 on it.
Asked for my help, I said He^&** NO it was rated for a 70 and I told him I wouldn't get in it if he did put it on.
Frank Acampora
Awww! C'mon Jerry--- Man-up! -No guts, no glory! Here is a 14 footer with a 125. Decals were changed to 85. You have seen it before. Wait until I get my 140 on it!
