Re: 70s Johnson 15- Fuel/Choke Problem?
Your motor has a low-tension magneto with the external coils. It also has a driver coil under the flywheel. Those mags can be VERY fussy about having the points gapped correctly and at exactly 180-degrees opposite. I would double check and reset the point gap and look for slop in the plate as it sits on top of the powerhead, as that can also cause variance in the point gap...
- Scott
