Re: 71 Johnson 60 HP does not restart
The BHP. is the big electrical plug where the wiring harness from the control, connects to the motor. it will smoke a lot in neutral, you could change to synthetic TC-W3 oil. also could do a decarb, and get the carbon out of the motor.
have you check your compression, cold and hot?
Decarb, take a can of seafoam put 3/4 of it in the gas tank, with only 1 gallon of premixed gas. put the rest in a spray bottle. start the engine, and let it come up to temperature. then remove plugs, and them some real good shot of seafoam into the cylinders, replace plugs, let sit 15 minutes. restart, and spray the rest of the seafoam into the carbs, so the the motor almost stalls, wait and repeat until the seafoam is gone.then take for a wide open spin. then put in new plugs, ad premixed gas to the tank, and take it for a wide open throttle spin. it is going to smoke like a house on fire, during this process.
afterwards compression.recheck
