71 Johnson 9.9hp carb rebuild
gmarshall43
Hello<br /><br />I'm cleaning a carburetor on a 1971 Johnson, 9.5 hp. Model Number 9r-71r. I got everything off except the high speed orifice. I can't get it out and I've applied quite a bit of pressure on it to turn it out. I'm affraid of busting it so I gave up and soaked it in carb cleaner for a couple of hours. Will this be ok or should it come out for a more efficent cleaning?<br /><br />Thanks
D
DJ
Guest
Re: 71 Johnson 9.9hp carb rebuild
It should be fine. Can you blow air through it?
