bobberstop
- Sep 3, 2016
- 59
I was cleaning up a little today, moving my shop vac and cyclone 10 times reminded me I was going to post how much I was impressed with the cyclone when grinding. I started out with no tenting in a garage (roughly 24'x28') thinking the holding the shop vac hose close to the grinder would keep the dust down, HA!! dream on!! It help for sure but the filter clogs in 5 minutes and best case you have to climb out of the boat dump the vac clean out the filter and the continue grinding. Worse case you don't realize the vac isn't keeping up and the garage is ground zero for fiberglass blizzard!! I will be wiping down tools for decades. So loaded with fresh knowledge gained from iboats sticky on grinding fiberglass, I picked up a couple of the bag inserts for the shop vac, amazing problem solved....almost. The bags are great for keeping the filter clean and maintaining suction but I have a smaller shop vac so the bag filled up fairly quickly, 15-20 of grinding. larger vacs would be better I'm sure. So I went to menards in search of a dust collector, and in talking to a employee he recommended this cyclone. The cyclone was also mentioned in the iboat sticky so for $45 I'm in, lots of places on the internet will show you how to DIY one but I was more interested in making progress on the boat then building a cyclone. You do need a container w/ a lid to mount it on (I use a 5 gal bucket, i would go bigger next time) and extra shop vac hose (had some from my last one). I hooked everything up, vac to top of cyclone hose to grinder out the side of cyclone. I did put a fresh filter and bag in the vac just to be safe. That little cyclone collected 99% of everything the shop vac took in. I never had to change the bag or clean the filter the rest of the 30+ hours of grinding. After a couple hours of grinding I would take a break and empty the 5 gallon bucket, never having lost suction the whole time grinding. Best $45 I've spent on this project so far!!! I'm not promoting any particular brand just the concept of using a cyclone in conjunction with a shop vac. I did attach a photo (Hopefully I'm not breaking any forum rules) of the one I used, sorry the hoses are detached had to use the vac to suck up water after washing out the hull. I'm sure this is old news to most, just throwing it out there. It will by no means stop and/or prevent the itch!!
