Hi,
Just got a boat/motor/trailer from some friends and have some questions and want someone to look over my virtual shoulder to check my thinking. Questions are numbered to help keep track of my tendancy to meander and use too many words when typing.
I checked the serial number and found a web reference that the outboard is a 1974 model.
It has been sitting in a barn for several years, and the last time they had it out he had trouble getting it started due to his weak shoulder but not sure if there were ingition issues as well.
It was about 20degF in the barn, but I did manage to pull the starter rope and felt compression in both cylinders. But due to the temp and the engine sitting for several years (2-3 maybe) I know it would be stiff just from that.
I have no idea if he emptied the carb or checked the lower unit fluid before parking the boat in the barn.
Right now I have the outboard laying on the garage floor off of the boat and I would like to find or buy or rig up an outboard stand before I do too much with it.
My thinking/plan/questions:
1. What is the gas/oil ratio supposed to be? I assume 50:1 but want to confirm that.
2. I plan to check the lube in the lower unit to check for moisture and ensure that there is something in there.
3. I will pull the plugs and check for spark and do a thumb-over-the-plug-hole to check for basic compression.
4. I plan to poke around the water drain hole to check if any mud wasps or other critters have build nests in there.
5. I may or may not get a carb rebuild kit, but initially I think I'm just going to see if it will run before spending any money on it.
6. The flipper lever on the side of the cowling, I assume that is forward/neutral/reverse, and I assume I want to initially start the outboard in neutral, and I probably want it idling before putting it into gear or when switching directions, correct on any of that?
7. Can I just slip this into neutral before the engine idles down? Or should I want until it fully idles down? I'm thinking of times where I might hit bottom or run into weeds.
8. They also gave use two spare dinged up props and said something about rubber between the shaft and propeller body to help avoid breaking a shaft if the prop hits a rock or something. Is there a way to check the spare props or the one on the engine to see if the rubber interface is still good or not?
I don't have a manual for the engine (yet), but have messed around with engines and a few outboards in the past, so anything I end up doing to this will probably be done at home.
Thanks in advance for any comments or answers.
Here is a pic of the engine before I removed it from the boat:
