76 evinrude choke trouble
pete j
My auto choke seems to be working fine until I turn over the engine and it pops the choke plates back up to no choke. I have tried adjusting the auto choke in and out of the sleeve but no matter were I put it the keep popping back up. Works great if I use it manually but it sucks taking of motor cover on first start up. Now Im lost at what to do to fix it. Its a 76 70 hp 70673D. Thanks for any and all help
oldboat1
Check the linkage at the solenoid, along with the ground. If "push to choke", could be the keyswitch. Check the wiring.
F_R
Bad key switch? Check input voltage at choke switch when key is turned to Start.
EDIT: Could even be wrong key switch (one that disconnects the "A" terminal when cranking). If that is the case, connect choke input to key switch "I" terminal.
pete j
Its not push to choke on mine it has a seperate switch for the choke and yes Im holding switch on. linkage all looks okay. I will check the ground cause I know its hooked up but that does not mean its good. Have had my fair share of things like that. Thanks for all the quick replys:) Oh and key switch is new and it does have push to choke but if I use the push to choke it would blow the fuse. Thats why the seperate switch witch makes me think F_R could be right
You should be looking into why the fuse blows.-----Look for bare wire.----Ohm test the choke solenoid.
pete j
The fuse dont blow with the separate switch but Thanks
F_R
Something's goofy with the wiring on those switches. Sorry, I don't know what.
oldboat1
Sounds offhand like you need to disconnect and tape off the choke solenoid wire at the key switch.
pete j
My guess is I bought the switch for my force 85 that has push to choke and my evinrude does not have it so I might have the wrong switch and when I turn the key on it makes everything haywire. Will find out more tomorrow when I have time to check but Thanks for all answers
pete j
Its been along time since I posted about fixing my choke which I just did today. and I would like to thank F_R for solving the problem and I cant believe how long I have been removing the cover which aint that easy on the water when the fix that F_R recommended took about two minutes. Thanks everyone who tried and super thanks to F_R :)
