Back to working on the 'ol girl. Our fish finder started doing weird stuff so we took the plunge and got a lawrence with gps woop woop!
We also threw on trim tabs, and boy is that a whooping. So the previous owners had drilled 18 small holes where the port trim tab now resides. Covering these with starboard was the best idea we had. Unfortunately that also meant the trim tabs were pushed out 1/4", both the bottom hinge and the top 3 bolts.
Since we unfortunately have our deck almost touching the transom, it was darn near impossible to reach down far enough to thread the bolts. We didn't want to trust sheet metal screws to hold the tabs. Closed end rivets are an option, but after much deliberation we decided on #10 bolts with washers on the back end with copious amounts of 5200.
Word from the wise: install trim tabs before your deck goes in. With 2 of us working, it took almost 4.5 hours to get these installed.
5200 gets everywhere. I mean EVERYWHERE. have multiple pairs of gloves available, paper towels, and brake cleaner / acetone for cleanup.
So because of lack of access, we had to mount the tabs 3/4" above the bottom of the boat. We'll let you know how well this works, or if it introduces significant problems. Our hope is that they will get out of the way enough once on plane. We do lose 1/4" of metal plate sitting still.
Also note the 1" hole we had to drill through the transom for the new fishfinder. That'll get a second coat of epoxy tonight.
