Larry Glady
- Apr 8, 2011
- 71
lost some power checked for spark, upper cyl has no spark and there is some arcing at the lower coil prob the only cyclinder firing should just replace both coils?? Thanx for any help Larry
It normally blows out a 10cents diode if you buy it at Radioschack, but a bit 'tricky' just to replace as it is all bedded into epoxy!!i guess thats what happened i thougth it would blow out the whole thing not just 1 side thanks for your help
