kanada
- Mar 15, 2011
- 76
Re: How to lay up the material on transom
There was one attempted bad repair done for sure. Just not sure if from factory wood was added in 2 layers separated by glass. Bottom was rotted through all the layers. The top indentation (see outside repair picture bellow) was rotted through, but the outside was separated by the layer of matt and resin and was good. That is where the transom makes a curve. So we kept it.
We had to fill in just the 6x4 inch triangle with peanut butter on each side because of the curvature of the outside skin
Prying out old wood with chisels and pry bars.
grinding - the messiest part of dealing with fiberglass.... good thing we had industrial mask. Previous repair was stuck on the gell cote. Poly resin does not stick to gell cote...... I pried it up with a screw driver in couple huge chunks.
Making the template for cutout.
Pre coating with epoxy before glueing with mayo....
Me in white shirt.
Me in white shirt.
