Well my 25 hp 1978 johnson seahorse 25R78C is not starting, after cleaning, adjusting and rebuilding the carb, it made a couple attempts to start but thats about it. I just pulled the spark plugs out and grounded them to the case and pulled the cord and I have no spark on both spark plugs. Then I took the coils off and cleaned and sanded the contact points. Then I took the flywheel off to see if I can service the points, but to my suprise there are no points, there are 2 little plastic boxes that looks like electronic ignition. What should i do now, is there a way to test or service that ignition system? How can I locate the problem? I dont mind replacing most of the ignition system, if it is going to give me a nice hot spark.
