Hello everyone. I just bought this smokercraft fishing boat that has this 78 johnson motor on it 115hp. The issue is the boat runs mint on muffs but as soon as its in the lake it does not want to idle. I did a compression test and there is 120psi on 3 cylinders and 118 on the 4th. Id i get it to idle in the water it dies as soon as it goes in gear. It tryed to adjust the idle screw but its all the way in cant urn it anymore. When is dies after i put it in gear it takes forever to start back up i need to choke it then put throttle lever on high and it will start. Any help will be greatful
