jesballs57
- Oct 25, 2003
- 10
hey guys<br /><br /> my rude is idling at 2600 rpm.with timing set a 4 btdc.also the throttle roller is off the cam so the throttle plates are closed ,i visually checked the plates to make sure.some how there to much air /fuel mixture getting in .the low speed jets are not adjustable .the only way i can get the rpm down is by retarding the timing to about 8 atdc with causes the idle to be rough and plugs to get wet.the flywheel key is ok so timing is correct.any ideas guys?
.by the way the number stamped in to the carb is 323302 any one know if this is the part # of the carb and if it is the right carb for my engine?
