Nivekt
- May 13, 2009
- 481
Hello Guru's,
I haven't greased either of these since I bought the boat 3+ years ago. When greasing the trunnion bearings, is it as simple as removing the pivot cap cover and slathering some marine grease on the bearings/liners? Do I have to worry about replacing the cap gasket once I pull it off or is it reusable?
As far as the steering actuator, how many pumps of grease should I feed through the zerk fitting? Will grease evacuate from some point on the actuator to show me it is full once I am pumping? Is marine grease okay or should I use something else? Ive done some research on these topics but its hard to narrow down my search parameters to get any usable results. Thank you for you time.
-Nivekt
-Nivekt
