Trying to free up the very stiff tilt on this motor. Engine has been sitting outside for many years but is otherwise in good order & now running (I rebuilt it way back when). Can get grease thru one side of tilt tube lube point (via nipple) but other side sat with broken off nipple. Have now cleaned out the hole and tapped in a new nipple but grease just wont flow thru.
Unsure if tilt tube (and big nyloc nuts at either end) are meant to pivot with engine but thats what is happening. Looks like the intended design allows for pivot in the main engine bracket boss - not at the transom brackets, as is the case.
Had the idea to remove the transom bracket arm on the offending side and see if I can drill a fine hole along the edge of the transom tube in parallel with the tube through to the nipple cavity. Using a 3 jaw puller, just cannot seem to get the transom bracket arm off the tube and worried about cracking the arm with too much force. Modest corrosion but its certainly not a mess. Maybe try ice, per below tip. I can order a whole new pivot tube cheap enough but so far looking like a hell of a job to change it!
Any thoughts please?
Flywheel removal tip: These flywheels can be very hard to remove! What worked for me was using ice to cool around the threaded end of the crank for say 25 mins. Doesn't matter if you also cool the inner boss of the flywheel. Then use a paint stripper gun (the electric blower kind that spreads the heat) to heat the flywheel evenly around the center, avoiding the crank, for 2-3 mins. Work quickly to stop the heat spreading to the crank - put your puller on, tighten, then give a few blows to the puller shaft. Try to support the flywheel weight with a breaker bar as you hit the puller to protect the main bearings & be careful not to prise too hard or you will crack something - its only alum!
Thanks
Mike
Thanks
Mike
