8000 lb cruiser twin merc 260's
Re: 8000 lb cruiser twin merc 260's
The bravo has MUCH more clearance.
Ayuh,... Only the Bravo IIs,....
I believe,...
The Bravo I,+ the Bravo III both are the same 8" from center of propshaft to Cav-plate as the Alphas....
smokeonthewater
oh heck..... If that is correct i may just cry.... lol I was up past 5 am reading about this stuff:eek:
hwsiii
Kevin, I am going to try and explain this assuming you have very little knowledge of propellers and what they do, but I have to use some terms that have to do with propeller technology, if you don't understand a term I use just google it so you can understand what I am saying.
Thrust is what is produced by a propeller to move a boat forward, and there are two types of thrust involved in this.
Static Thrust is determined by the diameter or blade surface area of a prop, and it is usually very large for tug boats as all they do is push very heavy loads at low speeds, it is also what helps get a boat up on plane quicker.
Dynamic thrust is determined by the pitch of a propeller and it is more of the deciding factor of maximum speed, very high speed boats usually try to control the pitch and diameter such that the pitch is twice the diameter of the prop.
I'm starting to think that increasing diameter along with other means of increasing blade surface I end up reducing slip in the lower speeds substantially but in doing so must reduce pitch to a point that I actually would lose a lot of top speed
It is starting to look like I need lots of low speed slip to get top end speed
This is NOT a true statement if you pick a balanced propeller for your boat. The right amount of blade surface area and prop geometry decreases prop slip at low end speeds as well as high speeds, which improves your top speed NOT lower it.
The key to good hole shot and good top speed is the balance between blade surface area, progressive pitch, blade rake and the cup of a prop. Look these terms up.
I'm afraid my boat is likely a bit heavier than either of us estimated... the best I can find is that 7200 is the base weight with one engine so 8400 with two plus another 1000 for a full tank of fuel and 500 for the genny extra batts and various accessories another 500 for fresh water throw in some people gear and supplies and if these numbers are correct I will likely top 11,000. I hope I'm over estimating
28 Monte Carlo
I show your gear ratio to be 1.32:1 not 1.5:1, please verify this.
Boat and Motor All up Weight
Prop Picker
Prop Slip
I expect your boat to run about 45 MPH at WOT and lightly loaded, and you should be using Solas Amita 4 aluminum 4 bladed props with a 17" pitch to achieve this. With twin I/O engines you are most probably stern heavy and need the extra stern lift from these props.
H
smokeonthewater
i definately have 1.5 or 1.47 whatever that range is
I am willing to consider changing ratio if it will improve the boat
My engines and drives have came from another boat and are not yet installed but my understanding is that the only ratio offered in this boat with alpha's was 1.47.... I think 1.32
is the bigblock bravo ratio
what do you think about the diameter..... is there a reason for the 14 1/2? Is that size mandated by being the max practical diameter that can be used with the alpha drive or does the smaller diameter prevent the engine from lugging at low speed with a pitch that is needed to load the engine properly at high speed..... I know that for maximum propeller efficiency in non planing hulls the largest practical diameter prop turning as slowly as possible is ideal
nada lists 7200 as base weight with one engine When I get it complete I will scale it
smokeonthewater
I actually have a fair grasp of alot of the basics as I have been designing airfoils since I was old enough to take an exacto to balsa and have been building radio controlled boats and aircraft for 25 years.....
the thing I am struggling with is the diameter..... pretty much every v8/alpha powered boat calls for a 14.5 inch diameter prop and I'm trying to figure out why and what if any gains could be found by circumventing the factor that limits the prop to that size..... Tonight I found this on lakeconroemarine.net
BRAVO TWO
Larger cruiser and nonplaning boat applications require more propeller thrust to get them moving quickly and to keep them moving at slower engine speeds for optimum fuel economy. All Bravo Two? drives will accept up to a 20 in. (50.8 cm) diameter propeller to maximize cruise efficiency. In addition to improving the planing characteristics of larger boats, the Bravo Two provides significantly higher reverse thrust for greater stopping power and better maneuverability.
I obviously do not have bravo 2 drives or a non planing hull BUT if "up to a 20 in. diameter propeller" will maximize cruise efficiency then why is it that while a 16" prop will physically fit on an alpha that merc suggests the same size prop for my boat as a 16' runabout with the same drive and engine
hwsiii
Kevin, every prop on every boat is a compromise, you can run 16" diameter props on your boat, but the largest pitch you will normally find is about a 14" pitch prop. Pitch and diameter are proportional in any particular make and model of prop, and when they design a prop they try to balance them for the best performance and prop Efficiency. And in almost all cases as pitch goes up on the same manufacturers make and model of prop the diameter normally goes down.
One of the potential reasons they could do this is because it makes it easier to know about how many RPM difference there would be between one pitch in the same manufacturer and model of prop and another one. So maybe the industry as a whole many years ago decided to try and standardize about how many RPM difference there is between each pitch in a particular make and model of prop.
There are a couple of other potential reasons why they could do this but I do not know EXACTLY why, I have never really put any thought into it, I am sure if i sat down and put some real thought into I could make sense of it, but I just accept it and use blade surface area to compensate for it.
There are so many differences in prop geometry that diameter is just one of the variables that we encounter when trying to find a better prop for a boat. If you really want to try a 16" Diameter buy a pair and try them on your boat and see how they work.
H
45Auto
Smoke, I hate to say it because last time I brought this up it was like I insulted the "gods of boating" or something, but I think one of the problems you're having with your prop dilemma is caused by the vast majority of people not understanding how power, gearing (propping), and drag are related.
Manufacturers (and almost all the internet "prop gurus") recommend that you prop your boat so that it reaches its top speed at maximum engine RPM. This is a good all-around compromise but is optimized for nothing but top speed. It also keeps people who don't understand what they're doing from burning up their motors thus is a smart move by the manufacturer so they don't have to replace motors under warranty. It?s also easy to do because all it takes is a speedometer and tachometer. This is what you?re seeing in all the recommendations. This operating parameter is taken as gospel. Although it is an EXCELLENT all-around, general recommendation that will keep the general public from over-revving OR under-revving their engine under normal use, it will not give you the optimum pitch for either acceleration or efficiency. With a fixed pitch prop and a single speed transmission, you can only optimize one thing. You have to choose between acceleration, top speed, and efficiency.
If you optimize for top speed, you don't give up significant losses in acceleration or efficiency and don't risk engine damage caused by under-revving or over-revving. For pulling up skiers, lower powered boats that may be marginal on power will often choose to not optimize for top speed, but to use a lower pitched prop that optimizes their acceleration at the expense of top speed.
Propped as generally recommended, your boat will reach its max top speed and you will not risk damaging your engine. However, your acceleration will not be optimal. To optimize acceleration you have to run a smaller prop (like 1st gear in a car) and accept the risk of over-revving the motor if you try to operate at sustained high speeds.
Propped as generally recommended, your cruise efficiency will also not be optimal. To optimize your cruise efficiency you have to run a bigger prop (like overdrive in a car) and accept the risk of under-revving the motor if you try to operate at sustained low speeds. However, due to the much higher drag of water as opposed to air, the gains to be made are minimal compared to the risks of high engine loads if you operate the engine below cruise conditions.
The manufacturer?s recommendations are the equivalent of gearing your car so that it reaches top speed in its highest gear. Only problem is that most boats only have one gear, unless you run a variable pitch prop or are into over 100 MPH water ski racing, like this boat (NWSRA is National Water Ski Racing Association):
FOR SALE
NWSRA Boat #471. 21' Hallett. 3A outdrive. 510 cu turbo Chevy by Power Marine. Over 1000 hp. Turbo 400 tranmission. Newer trailer. $20,000 or make offer. Contact Dave Allen at 541-312-8305
Notice that it has a Turbo 400 transmission in it. This is because the water ski racers need to optimize acceleration AND top speed. You can't do both without a variable-pitch prop or a transmission, and I don't know of any variable-pitched props sized to handle 1000 HP.
In the automotive world, where powertrains that are designed for speed ALSO have to meet government efficiency standards, you?ll find that efficient, higher powered cars are NOT CAPABLE of reaching their maximum RPM or top speed in the highest gear. Top gear is a very high overdrive gear used only for gas mileage and cruising. You?ll find that you have maximum acceleration in the lower gears (hopefully this is obvious to everybody), maximum speed where the power peak coincides with the drag curve (not necessarily in top gear), and maximum efficiency where the engine is turning as slow as it can (overdrive) and still deliver the HP required due to drag.
For example, a Z06 Corvette has maximum efficiency (24 MPG) at 1400 RPM at 65 MPH in 6th gear. It generates maximum horsepower (505 HP) at 6300 RPM. If it could rev to its HP peak in top gear it could do 292 MPH. Unfortunately, the power required due to drag exceeds the power available from the engine in 6th gear at 180 MPH (3900 RPM) so it can?t turn any more RPM or go any faster in 6th gear. However it's top speed is 198 mph. Top speed is achieved in 5th gear at 6300 RPM where the power available peak (505 HP) coincides with the power required (due to drag) curve. The same thing happens in boats, except that it is much more exaggerated because of the higher drag of water as opposed to air. To begin to understand how it works you need to be familiar with the basic principles in this thread:
http://forums.iboats.com/showthread.php?t=225803&highlight=secrets
which shows an under-propped (acceleration) case, a normally (general public ? top speed) propped case, and an over-propped (efficiency) case. The problem with the over-propped case is that while your boat will be more efficient at a certain speed, your top speed will be slower than it could be and you are risking over-loading and damaging your engine under sustained operation at lower speeds.
Your boat is like a car with an automatic transmission in which you have a choice of one gear to lock the car into (the propellor in the water is analogous to the torque convertor). What this means in boating is that if you prop your boat for max efficiency it would be like locking your car in overdrive. If you're driving in the city in stop and go traffic with a max speed of 10 MPH, you're going to be lugging your engine horrendously and fry it real quick. You'd be better off locking it in first gear.
However, if you want to drive from Florida to California, going 15 MPH with the engine screaming at maximum RPM in first gear will kill it quick. If you're only accelerating from a stop once or twice a day, you'd be better off locking it in overdrive and cruising 70 MPH at 1500 RPM all day.
To finally get to your prop diameter question, you'll find that if you propped your boat for maximum efficiency as opposed to maximum top speed, you'd be using a bigger diameter, high pitch prop that would be incapable of reaching the recommended maximum RPM of your engine (just like overdrive in a car), because the additional drag due to the bigger diameter increases exponentially at higher speeds and RPMs. You will also pi$$ off all the prop gurus and they will talk bad about you. If you were to use that prop for sustained operation below cruise, or for skiing, or pulling tubes, it would be like driving your car around town locked in overdrive. As a general rule, the disadvantages would FAR outweigh the advantages. A manufacturer that propped a boat like that would be replacing engines under warranty left and right. Anybody that recommended it would have people crying at them that they burned up their motor. But if you plan to get in your boat and cruise at 25-30 MPH for 4 or 5 hours, the big prop would give you higher efficiency, and the additional load on the engine as it accelerates to cruising speed once or twice a day would be insignificant.
The only way I know to optimize cruise like this is with a GPS, a fuel flow meter, and experimenting with different props. And once you do, I would imagine that the gains you would see would be in the ?couple of percent? range at best as opposed to using the ?normal? or recommended propping, due to the inherently high drag of water as opposed to air. It doesn?t make sense to me to worry about it with such minimal gains. Prop it so it reaches max speed at max RPM and be done with it.
My boat is 23 years old and has 600 hours on it, and I would estimate that at least half of those were spent idling around at ?no-wake? speeds. 20 gallons/hour is supposedly the fuel burn rate at most efficient cruise on my boat. That?s cruising at a speed in the low 20?s so it?s getting better than 1 MPG. 300 hours at 20 GPH is 6000 gallons burned at cruise. So if the original owner had put a set of ?efficiency? props on it and saved 2% in cruising fuel, it would have saved 120 gallons in 23 years. It wouldn?t even have offset the cost of the set of props.
Given the size, weight, and speed range of our boats, I wouldn?t be surprised that if you went with twin Bravo II?s and bigger diameter props, then any efficiency gains you see from the bigger diameter would be offset by the additional drag of the prop and the additional drag of the bigger lower units.
Traditionally here we?ve had very cheap fuel prices relative to our income. Its been proven over the years that for our small, recreational planing boats the smaller, higher RPM props give up a little performance at acceleration and give up a little efficiency at cruise, but don?t risk frying the engine and thus are the best choice for all-around usage. Its always been very common to swap on a smaller prop for more acceleration. Don?t be surprised in the future to see some re-thinking on prop sizes as fuel becomes more expensive.
smokeonthewater
you have brought up several points that I have been working on..... I do know that I can get 16" props in up to 18 and I think 19 pitch.... I have a 16x14 on the carver now but never ran it enough to do any mpg figures.... I have been suspecting that basically nobody really knows the answer to my question (no insult intended) There is ALOT of confusion around propellers in general to the point that it is just assumed by most everyone writing guides and articles on the various web pages that not only is the reader totally ignorant of basic physics but is also unable to comprehend them.... I have probably read 200 pages on propellers in the last couple weeks and mostly I have read the same brief primer over and over again... It may well turn out that there are factors at work here that are plain as day once discovered but it seems as if the industry veiws the idea of sharing this information as unimportant... It is also very likely that the market I am representing is such a small niche that there is not much incentive for a manufacturer to exploit it...... I really expect that I will eventually find that a pair of 4 blade 14.5x17 or 14.5x18 alum will be the best logical chioce for my boat but This still interests me.... I may try a couple phone calls to manufacturers but I fear that It would take hours to get to the point that I was talking to someone who actually studied the theory and application of propellers instead of a "phone answerer" with the same prop calculator on their computer that I have here..... :cool:
I agree whole heartedly about the torque converter analagy except I don't think you would go up in pitch to run a larger diameter prop and that it could still be propped to run top speed full throttle without over reving.... That is what I did with the carver... I started with 15x17 as that was the factory spec'ed prop but Ii didn't have enough power to run it with my 305 and the 1.5:1 outdrive annd it was sluggish and topped out at 16 mph and 3800 rpm.... I then swapped to a 2:1 drive and a got little more acceleration and 33 mph top speed at 5500 rpm (too much) next I tried a 14.5x19 stainless and while rpm's came down to 5000 performance went way down..... my next move was to go back to 1.5:1 and a 16x13 and holeshot was amazing but I only got 22 mph at and 4800 rpm (not full throttle)... next I went to the 16x14 and got 27 mph at 4800 full throttle..... these numbers may be a little off up or down but are pretty close
hwsiii
45Auto, let me compliment you on your charts and the theory in your prior posting, that is an excellent White Paper in my opinion and I know you spent some time and effort on it to try and educate and transfer knowledge to help people here on the forum. There are NO prop gurus on here that I know of, there are just some people who have more knowledge and experience than others in certain areas, and hopefully they try to transfer that knowledge to others and help people have a better understanding of props and also help them find better props than they have now on their boat.
(Note - I used these kinds of charts very successfully when racing cars in the late 80?s and early 90?s. The prop pitches are analogous to the gears in a car. You shift gears at the speed where the pitch lines cross to maximize the power available at the rear wheels. If these pitches were gears and the POWER REQUIRED line was farther to the right like it is in a car (air friction is much less than water friction), you would shift from 1st to 2nd at 54, then 2nd to 3rd at 63. Shifting by the tach wouldn?t maximize your acceleration because the gear spacing wasn?t even like it is in this example.)
In my opinion, though I am very sure that these charts work very well for cars, they have to add RPM on the right side of the chart for them to be appropriate for boats and propellers. You cannot use HP the way it was used in this chart. Theoretically you assumed that all the props were going to attain the same HP and RPM even though they can?t do that, if they are the same make and model of props. You did keep the Prop Slip the same for all of them but when you plotted the curves for Power Available for each individual prop you have them all attaining 5,000 RPM, and that doesn't happen. The Power Available curve for each prop is separate but you have to show the curve for the 23? prop crossing the Power Required line at 4,130 RPM and 265 HP, and the 27? prop will cross the Power Required line at 3,590 RPM and 240 HP and not scaling all the way up to 280 HP. When you do this you will find the chart looks very different, as it will show the dramatic differences in Available HP between the props. I drew Blue lines across the chart where each prop should actually pass through the Power Required curve. If you could, it would be nice to see the chart redone by the correct RPM instead of by using HP so we can see the differences in the new chart. Although they won?t be right because of the much higher slip ratio at lower speeds it gives people an indication of the differences in each prop pitch and how much Power Available changes between each prop. If you can?t do it just let me know and I will do it.
Power Available and Power Required chart
Prop Pitch change
Prop Slip
As you can see the motor is lugging very bad with the 23" pitch prop and I wouldn't give the motor running the 27" pitch a longevity of any significant length of time. As it will only be running at 70% of maximum RPM, this means it will not be able to pull enough air into the carburetor to have an efficient air to gas mixture which I believe will cause combustion problems and a buildup of carbon in the cylinder, BUT I am definitely not a motor person and am more of a mathematician, so maybe you can give me some insight into this 45Auto, as I know that you are very knowledgeable in that area.
Prop Slip
I would appreciate hearing your thoughts on my opinion of how to show the most realistic chart and what that does to the chart. Please do not take this as any kind of reflection on the work you did earlier, as you did the best you could with the theories that you have worked with and from your experience in the past with race cars. I promise you, I NEVER make an error, UNLESS I am breathing and could have made an error here, LOL.
H
45Auto
Hwsii,
I don?t have time to go into detail now, and it?s very difficult and cumbersome trying to discuss engineering basics through this forum format. For example, the ?Power Secrets? post ran up against the character and graphic limitations of the forum and I had to cut down the word count significantly to get it to post. We?re only about 80 miles apart, we could get together sometime and go over it if you'd like.
The ?Power Required vs Power Available? graph IS a propeller chart. They are the exact same for airplanes, helicopters and boats except that the shape of the ?power required? curve is different. They are critical for airplanes and helicopters. If your power available falls below the power required curve, you fall out of the sky. In a boat all that happens is you slow down a little. A propeller doesn?t know if it?s turning in air or water, the basic principles are all the same, only difference is the Reynolds number. (Reynolds number is a dimensionless number that includes viscosity, density, and flow rate ? obviously different for air and water). I?ll try to post a couple of links when I get a chance.
There?s a couple of major misconceptions in your last post:
There?s an error in your spreadsheet that shows that HP required at 54 MPH varies from 235 HP to 280 HP as prop pitch varies. Although power required will be slightly different (less than 1 HP), the only difference is due to the induced drag of the prop. The difference in induced drag on our props (little props, light recreational boats) will be so small you can?t measure it. At 54 MPH the ?HP Required? will be a constant, NOT the swing between 235 HP and 280 HP that you produced. The power required at 54 MPH will be 240 HP, as shown where the vertical black line you added at 54 MPH intersects the black power required curve, no matter what prop is on the boat.
The graph below shows the prop performance of an 80,000 ton tanker with a 7.2 meter (23 feet 7 inches) diameter prop. It shows how the power and RPM required to drive it at a constant 14 knots varies with pitch. As you can see, the power values range from a low of 8800 to a high of 9300 KW (1 KW is 1.34 HP, so we?re talking over 10,000 HP). That?s a 5% swing in power over a pitch change of over 92% (12 foot pitch to a 23?7? foot pitch) driving the ship at a constant 14 knots.
P/d of a 19? pitch, 14? diameter prop is 1.35. P/d of a 23? pitch, 14? diameter prop is 1.65. Pitch change from 19? to 23? is 21% as opposed to the 92% in the example. Our little 19? to 23? pitch props are not going to see a measurable difference in induced drag. Realistically it?ll be so small you can?t measure it, much less than 1%. But even if we call it 1% that?s still only 2.8 HP, NOT the 45 HP (19%) difference you show.
There?s another major mistake in the way you marked up the original graph by adding RPM on the right side. A meaningful graph cannot be made the way you tried to add RPM on the same axis as HP. You can?t have horsepower and RPM on the same axis because one particular HP value is NOT specifically linked to one particular RPM. In other words the same amount of HP can occur at more than one RPM. See how the red lines on the GM chart below show 290 HP occurring at both 4600 and about 5100 RPM? That?s why HP and RPM must be on different axis.
I?ll be busy the next couple of days, I?ll try to put something together this weekend. But if you want to add RPM to the ?Power Required vs Power Available? graph, it?ll look something like the one below, NOT what you did. Each pitch would require it's own RPM scale on the same axis as speed. I added them below at the max HP point and the point where each prop runs out of power against the power available curve. You can see that the 19" pitch would do about 57 MPH, the 23" pitch about 59 MPH and the 21" pitch about 61 MPH. It would have been easier to explain with a separate graph for each pitch before I combined them, but we're limited by the forum constraints.
smokeonthewater
I also noticed that one or both of you (can't remember) stated that diameter was a factor of pitch and blade design but everything I have found online states that diameter is a factor of horsepower and propeller rpm (design engine speed x gear reduction)... I also see that diameter is varied to hull design and vessel speed.
hwsiii
D45Auto,
Me
45Auto
Then the correlating theorem should be that the 19" prop, if I just let the motor run up to enough RPM to to stall beause of the load, and 23" and the 27" prop will all do the same speed, since they all max out the 280 HP, is that right.
H
45Auto
That is incorrect. You are still not understanding the black "Power Required (PR)" curve. Your statement above is like saying your car will go the same speed in every gear. It will produce the same amount of power in every gear, but it will NOT go the same speed in every gear. Changing prop pitches (or diameter, but pitch has more effect on our little props) on a boat is exactly the same as changing gears in a car.
To use the "Power Available vs Power Required Graph" pick a speed at the bottom and go vertically up to the "Power Required" curve. From that point on the black "Power Required" curve go horizontally left and you can read the amount of horse power that is required to go at that speed.
As an example, pick 50 MPH. Go vertical to the "PR" curve, then horizontal to read the horsepower required to go that fast. It is about 175 HP. If the "Power Available (PA)" curve for a particular prop is above the "PR" curve, then that prop can deliver more power than is required.
Now ignore all the other prop curves except the yellow 19" pitch curve. Go straight up the 50 MPH line till you intersect the yellow 19" pitch curve. Go horizontally left from that intersection point and read the WOT horsepower available from that prop at that speed. In this case it would be 300 HP. This tells us that the 19" pitch prop would easily go 50 MPH at less than full throttle because while 175 HP is required, it is capable of delivering 300 HP at WOT at 50 MPH. Now imagine you are cruising along at 50 MPH at part throttle, while delivering 175 HP. If you slam the throttle to WOT position, the engine immidiately begins delivering 300 HP. The additional 125 HP, above the 175 HP required to go 50 MPH, will be used to accelerate the boat.
To find the max speed of the boat with the 19" pitch prop, look for the point where the yellow 19" pitch curve crosses the black "Power Required" curve. Go straight down from that point and read the MPH on the bottom scale. In the case of the yellow 19" pitch curve, this point occurs at 58 MPH. To find the HP required to go 58 MPH, go horizontally left from that point where the yellow 19" line crosses the black "PR" line. You will see that it requires about 260 HP for this boat to go 58 MPH. At 5700 RPM the motor is only capable of producing 260 HP at WOT. There is no additional HP left over for acceleration so the boat can't go any faster.
You can follow the same process with the red 23" curve and the blue 27" curve. Note that the 175 HP required to cruise at 50 MPH doesn't change if you change props. It's controlled only by the black "Power Required" curve.
Go straight up 50 MPH till you intersect the red "Power Available" 23" pitch curve. Now go horizontally left from that point and read the "Power Available" at 50 MPH with the 23" prop. It's about 280 HP. So this prop can also go 50 MPH since it has 280 HP available at WOT but only 175 is required to cruise at 50 MPH. So you can cruise at 50 MPH using part throttle to deliver only 175 HP. But remember you have 280 HP available at WOT. So if you hammer the throttle to WOT the engine will immidiately produce 280 HP while only 175 are required to cruise at this speed. The excess 105 HP will be used to accelerate the boat.
Remember how the 19" pitch prop was capable of producing 300 HP at WOT at 50 MPH, so it had 125 excess HP available at 50 MPH? Now the 23" pitch prop at WOT at 50 MPH is only capable of producing 280 HP. So it only has 105 excess HP at the same speed of 50 MPH. Which one do you think will accelerate faster from 50 MPH, the 19" pitch with 125 excess HP or the 23" pitch with 105 excess HP? Hopefully you said the 19".
To find the max WOT speed with the 23" pitch we look for where the red line crosses below the black "Power Required" line. Go straight down from that point and you will see it is 60 MPH. So the 23" pitch prop's WOT speed will be 60 MPH at 4800 RPM.
You can follow the same process with the 27" pitch prop. Up from 50 MPH then left from the intersection point with the blue 27" pitch line shows that at 50 MPH it is capable of producing 240 HP. It needs 175 HP to cruise at 50 MPH, so it has an excess of 65 HP available to accelerate from 50 MPH. This is less than the 19" at 125 HP, or the 23" at 105 HP, so it will be the slowest accelerating of the 3 props from 50 MPH.
Top speed for the 23" pitch is where the blue line crosses the black "Power Required" line. Go straight down from that point and you will see that it's at about 59 MPH. Go horizontally left from that point and you will see that it takes 290 HP to go 59 MPH in this boat. At that point the engine will only be turning about 3800 RPM, but it has no excess power to allow it to go any faster.
To sum up, it takes 300 HP for this boat to go 60 MPH, 290 HP for it to go 59, and 280 HP for it to go 58 MPH. Note how this follows the "10 HP per additional MPH" general rule (which is controlled by the slope of the "Power Required" curve). You can also see how the 23" prop is fastest because it puts the engine's HP peak directly on top of the "Power Required" curve. The 19" pitch puts the engine's HP peak to the left of the "PR" curve, so the engine is overrevving before it reaches max speed. The 27" pitch puts the engine's HP peak to the right of the "PR" curve, where it is unable to develop enough power to accelerate to it's potential 300 HP peak before the drag overcomes it.
Figure 4.6 (section E, bottom of the notes) on the Michigan Institute of Technology lecture notes in the link below shows a similar calculation for a prop plane. The shortest time to climb will be where there is the most excess power, in other words where the distance between the "Power Required" and "Power Available" curves is greatest. The planes top speed would be where the "PR" and "PA" curves cross. To the right of that point the power required to go at a higher speed is greater than the power available from the engine. The boat graphs work the same way.
http://ocw.mit.edu/ans7870/16/16.unified/propulsionS04/UnifiedPropulsion4/UnifiedPropulsion4.htm
smokeonthewater
and is this all theoretic speed where actual speed will be less based on percentage of slip? or is that figured in with some figure I missed
hwsiii
45Auto, I don't know much about horse power, I do understand what you are saying, but it does not match up when you use motor RPM and prop pitch, and they should match. The math for prop pitch changes and prop pitch times RPM are simple and straight forward.
Let's make one assumption, that the motor with the 19" pitch prop turns 5,450 RPM at WOT, If you don't like this assumption give me another number to work with and I will use it because the math doesn't change.
Prop Speed from Tachometer
(Original Prop RPM from Tachometer RPM / Gear Ratio) = Prop RPM
5,450 / 1.5 = 3,633 RPM at prop
Outdrive RPM X Prop Pitch = Inches of forward Movement
3,633 X 19" = 69,027 Inches of forward movement
Inches of Forward Movement / 12" in a foot = Feet of forward movement in a minute
69,027 / 12 = 5,752.25 Feet
Feet X 60 Minutes in an Hour = Feet per hour
5,752.25 X 60 = 345,135 Feet
Feet per hour / Feet in a mile = Miles Per Hour
345,135 / 5,280 = 65 MPH
MPH X 90% Forward Movement with Prop Slip = Actual Forward Movement
65 X .9 = 58.83 MPH Actual Forward Movement or 59 MPH[/B
This proves that the motor turning at 5,450 with the 19" prop does 59 MPH with 10% prop slip then the 23" and the 27" have these mathematically corresponding RPM.
When I convert the other two props ( by pitch) to find out how many RPM they will turn with the change in pitches these are the numbers.
New RPM after Prop Changes
Tachometer RPM X (Original Prop Pith / New Prop Pitch) = RPM for New Prop Pitch
5,450 X (19/23) = 4,502 maximum WOT RPM for 23" Prop Pitch
5,450 X (19/27) = 3,835 maximum WOT RPM for 27" Prop Pitch
And when you multiply these RPM by the different pitches of each prop as I did for the 19" prop this is what you have.
Prop Speeds with 10% Prop Slip
So if what your chart shows is different, I have to believe my mathematical calculations, as they are simple and straight forward.
And if you will run your chart with RPM instead of using HP you will see that I am right.
H
rbh
It is nice to see you guys mentally duken it out, but can you please come to a consensus. Your thrown me and possibly smoke for a loop on this one.
45Auto
5450 RPM is a bad assumption to use as an example to try to explain. There is no hard data to tell how much HP the motor is making at 5450 RPM. We could extrapolate the curve, but it would be better to use an RPM where we know the HP. From the spec sheet below, 4800 RPM would be a good. We know the engine makes 292 HP at 4800 RPM. We can read the HP at other RPM's off the curve.
So if what your chart shows is different, I have to believe my mathematial calulations, as they are simple and straight forward.
Can't control what you believe. If you want to ignore horsepower and drag that's up to you.
Your chart shows 59 MPH with a 19" pitch at 5450 RPM (270 HP if we extrapolate the dyno chart).
Your chart shows 59 MPH with a 23" pitch at 4502 RPM (290 HP from dyno chart).
Your chart shows 59 MPH with a 27" pitch at 3835 RPM (250 HP from dyno chart).
So you believe that the same boat takes 3 different amounts of power to go the same speed? Or do you believe that the engine makes the same amount of power at 5450, 4502, and 3835 RPM?
I'll re-do the chart with RPM for you and you'll hopefully be able to understand where you are wrong. Please re-run your calculations based on the 19" prop at 4800 RPM (292 HP). EDIT - Use 23" at 4800 RPM, it will allow the demonstration of an under-propped and over-propped case.
(If you could shrink the width of those chart pics you posted in #29 down some, this thread would be a lot easier to read. They're forcing the edges of the forum off the side of my screen.)
smokeonthewater
I'm pretty sure my prop diameter question has been long forgotten....
Tail_Gunner
:D Nope ill post some pics in a while..Very simple stuff..But the above thread is intresting is it not...I never thought that boat.. hull... prop design could be so linear..;)
Could we get into drag coefficiency and lift..Now that would be intresting..
