Nickstoyz
- Jun 11, 2018
- 79
Hello, so two outboard same problem . A 25 and 35 hp. First start of the day, starts right up and sounds great. go to give throttle and maybe only get half power at wot. The motors sound ok when doing this but no power. Turn them off to fish for a bit start back up no change. After a while of running they will spudder or studder and you can hear that the engine wants to go fast then just like that the motor runs great!! New plugs. Fresh gas. This is the best way I could explain it. short version of above is like they run on one cylinder at first then just like that two cylinders. I guess I should mention that they both run great with muffs. I'm lost.
