81 Checkmate
- Jul 20, 2010
- 1,360
Re: 81 Checkmate Restoration!
Update - Been sanding/fairing and filling the hull for the last month or so....
Going with a Black bottom and Yellow top side with Black accent in some rasid areas.
220 grit over the whole hull...
80 grit and then 120 over the fiberglass filler, then filled deep scratches with spot/glazeing compond then 220 over that.
Used Accetone to wipe down then clean cloth over that.
Sprayed one coat of primmer....waited 24 hrs.....then dry sanded with 400 grit...Accetone wipe down, then one coat of gloss black.
The worst part is laying on your back to do the bottom. Ugh! My back is sore and my arms are ready to fall off.
Surely if i had to do over i would flip the boat! Not an option for me as my garage is to small.
