81 Glastron SX-190 Transom and Engine- PICS Galore Update 11-8
26aftcab454
Re: 81 Glastron SX-190 Transom and Engine- PICS Galore Update 11-8
UPDATE: motor3.jpg another reman from City Motor Supply Dallas-- .030 over--flat top pistons, hardened push rods & rockers, race bearings, APR head bolts, mild flat tappet RV cam-same Edlebrock intake & qudrajet, same Blaster II ingition & exhaust .
The windage tray & oil pan were trashed so I orderd a nice windage tray from hot rod shop & original oil pan would not clear. Got a deal on what I thought was a 8qt pan but was 10qt.:eek: with extended oil pump pick up to a high volume oil pump.
Met up with Clockwatcher(Johnny) futura.jpg and drooled over his Futura at the local sand bar today-Great guy!-We and several other boats got caught up in a bad pop up storm and had a blast haulin' butt down the lake.One of our good buds shatterd his side windshield suffing a wave and his GF had glass imbedded in her leg. Mine is has a couple hours left to break in that cam so I ran 3000rpm with a couple blast to 4500rpm-rode like a dream-it was still pulling hard..another weekend and I'll change the 10qts of oil and zinc additives and see what she can do.
I'm still running the 31 year old MR-1 drive with a 19 pitch prop. Might try a 21". I have to be real careful on take offs out of the hole and want to install a drive shower to help keep the drive from melting. The original 305 Jay pulled out was maybe 200hp and his 350 was just under 300hp. The new motor makes a good bit above that.:cool: I hope the drive hangs on till next year. I know I'm pushing it.
-in April 2012 had a valve drop into cylinder while running at 3200rpm. zombieblock.jpg-made hole bigger than my fist in the cyl wall-not re-sleeveable.
The boat was parked in the street in front of my house awhile back and my nieghbor backed into it. Tore up the ladder and added some scrapes & dings plus damaged trailer. It was repaired. I left the plug out a couple times and replaced the starter & blower.Ibacked under a tre inmy yard and had to replce the bimini. And for some reason had to replace the nylon bushing on the drivers seat after a week of ownership..it may have been over stressed LOL.
Jay did a great job rebuilding and has offerd plenty of support- but feel like may be disapointed him some. 2012713.jpg it is still a cool boat.
Willyclay
Ok, I'll play! New engine? Old engine? Link to another thread?
Willyclay
Thanks for the update. Glad you are up and running again. Good luck!
Spinnaker
Great project. Boat looks fantastic! Well done! Mine was a similar adventure.
26aftcab454
DSCF0003.JPG22712boat.jpg it does not suck.
79Merc80
I have the same boat, but with a closed bow 1981 Glastron SSV 194. Same 228hp 305. I was able to get to almost 50 when I chickened out, cause I didn't want to run it that hard. MIne also has the same spiderweb stress cracks right about where the throttle handle is.
Craig
26aftcab454
nice looking boat Craig!
What prop are you running?
I have a 3 blade 19 pitch that has a great hole shot and hits 55mph at 4600 rpm.
