What I meant in post three was new plugs and then the stuff in post two.
Stop, Step Back, Take a deep breath....
Now:
1. Compression test. Post results
2. Open air gap spark check set at 7/16", post results.
3. Fuel sample into a clear jar, post results.
4. With motor just barely tilted (just enough to get a downhill slant on the carb throat) and with air silencer removed, squeeze bulb with arrow pointing up till firm.
Gently continue squeezing the bulb. If bulb continues to depress search for the fuel leaking. Its probably coming from one of the carb throats. Report results.
Disregarded everything on the motor in the past and did the basics.
Compression: 120psi on both cylinders
Spark: Spark clears 7/16" gap, but was still curious and hooked up my spark tester and the light in the tester flickers on both coils, even with brand new plugs.
Fuel: Everything checks out great within that, no leaks and fuel looks great.
My main concern is the intermittent spark occurring, its obviously enough spark for the motor to run but this is the cause of the rough running?
Going to head over to CDI trouble shoot and double check everything, but is it almost safe to say the power pack is going?
