84 johnson
mnevill
75 horse starts great,idles great,compression in all 3-cyl. is 120-123...but when i give it gas it boggs down and i have to go slow until i get it up a ways and then it runs great...it seems to help if i push in on choke ...carbs have been cleaned but did not help....any ideas?
bktheking
Re: 84 johnson
If it helps to adjust the air/fuel mix by fussing with the choke you are correcting the issue, sounds like it's still a carb issue, something dirty-did you pull the screws and clean the orifices, wrong float level, something isn't right about the carbs.
