1985 120 evinrude,sn G1025123,when I go to WOT to plane boat out there is no extra power as in the past,I have to get someone to sit in front of the boat to get it to plane,at one time I could go 55 mph,now all I get is 35 mph,I dont here that extra voroom when I full throttle.<br /> Also my tach jumps around and does not work most of the time.I checked for loose conections at the tach,not sure were to check at the engine,I do know that my voltage regulator/altenator is bad because my battery does not charge, but is a good 12 v,Stator tested ok,could this be causing my other problems?
