It is a 25hp. I have a factory service manual but it is not very clear in this area and I was hoping to get some first hand tips on how to replace the shift rod seals. I am going to try and pull the prop shaft carriage to replace the prop shaft seals. Is the shift rod disconnected from inside our outside. Not much space to pull it from the outside in the water intake opening. Looks like there should be two orings that I need to replace to form the seal on the shift rod.
