flatfisher
- Jun 15, 2010
- 4
Ok, well... i got this boat after sitting in an open field for 15 years, it is a 21ft custom made flat bottom aluminum boat. It had a 85 suzuki dt 140 on it, it was in pretty beat up shape but i got it running, runs pretty good for a motor that sat for that long, it has some damage on the anti ventilation plate on the lower unit that i am repairing... broke a few bolts around the water pump and whatnot... pretty basic standard stuff i guess... i just cant figure out how the heck to put the shift rod/shaft back into the lower unit to line it up with the gearing... i have searched and only found info about pulling the gear housing out to do it... but i just want to know if there is another way to do it without taking more stuff appart... thus ending in more broken bolts, more bad words, and more grunt work. Thanks in advance, if this has been posted here before then either i am using the wrong key words, or something else is up.
