drowningworm
- May 4, 2011
- 5
I have an 85HP force outboard that is on an 87 bayliner capri that has had a recent rebuild. The compression on all three cylinders is 120psi. This is the first time attempting to start the engine since i have owned it. (bought it with low compression in #2 cyl... due to carbon buildup sticking the rings in the piston). I have checked the timing with an inductive timing light and it appears to be very close to right on. The engine will fire and almost start and then backfire and die. Any ideas?
