85 hp Johnson '''
theginns
Just two quick questions for you. What is the part called that when you lower your engine, it rests on a bar that you can adjust by moving the bar up or down through the holes in the motor mount. Also....where can you find these? Thank you.
ezeke
Re: 85 hp Johnson '''
It's called a thrust rod assembly and is model-specific. Get it from any J/E dealer.
