'85 Mercury idle stabilizer
Dmunch
Will a bad Mercury idle stabilizer cause the motor to limit the RPM's to 2200 or is that a different problem?
achris
More fish than mountain goat
Re: '85 Mercury idle stabilizer
Need a bit more information that 'Merc 85'.... Let's start with year, and serial number. And as far as I know, they don't do a 4-stroke 85, so I'm not going to ask that question... :facepalm:....
Chris..........
Faztbullet
On your 115 hp the stablizer will not limit rpm, beteer to disconnect it all together as it can cause engine damage from over advanced timing..
Chris1956
Sounds like a problem with the high speed stator windings.
Dmunch
thanks. already replaced the stator but found out the reeds on one of the blocks are not good.
Chris1956
So you think a reed valve is limiting your RPM?
