85HP Heads
Simple_Man
My motor just stopped on me, while cruising on the 4th. Wouldn't turn over pulled the plugs still wouldn't turn. I got it home spun it by hand. I pulled the head to check for damage I think I had water intrusion in a cylinder. one cylinder is a bit cleaner than the other 2 no gouges on the walls. Is the gasket material between the two parts of the head permatex ?
Nordin
Are you talking about the head gasket?
The head gasket is just a head gasket no Permatex or other liquid gasket there.
If you have water intrusion in a cylinder the head gasket, exhaust cover plate gaskets or a crack in the water jacket are possible issues.
jerryjerry05
Put it back together( if possible) and do a compression test.
Low comp does what you described(hard turning over).
Post the results.
Simple_Man
Sorry I guess I was asking about the water jacket cover. It had some sort of rubbery substance for a gasket. I was wondering if that was ok, or should I get the proper gasket.
Simple_Man
I put the head back on, I used the old head gasket, and permatex for the water jacket cover. I have 130lbs on all 3. Turned over started fine on muffs. I am still wondering what would cause it to just stop while cruising, and not be able to spin the fly wheel. any ideas?
jerryjerry05
Maybe you blew a head gasket.
The uneven comp can cause the no turn.
Yu use Permatex or silicone to reinstall?
You might have fixed it?
I'd look for a new gasket as the old might not last?
Simple_Man
head gasket is dry. the other plate that covers the water jacket was sealed with permatex. is there a gasket for the water jacket plate or is it supposed to be permatex? head.jpg
Nordin
No there is no gasket for the head cover plate, soo use Permatex or other liquid gasket brands.
Simple_Man
Thanks Nordin!!! I took it out today ran better than it ever has. Still wondering wht caused it to just stop though. And I'm going to replace the head gasket when the new one gets here.
