chuckz
- Aug 22, 2004
- 625
I purchased a used Force 85HP I was told it was a runner. After much troubleshooting I have discovered low compression. As part of maintanence I had the heads off and replaced the head gasket. The original machining marks were still in the cylinders. There was no carbon in the rings where I could see them. I suspect the rings are not seating because of being glued in place by old gas. After I tried to start this engine, I realized it hadn't been started in years. I had put oil in the cylinders, Deep Creep, before trying to start it. What is the best way to get the rings unstuck?
