jdparsons1
- Jun 22, 2003
- 16
I have a 87 Bayliner capri and when I pull the throttle handle out for neutral and then try to push forward before starting the motor it won't let me. I thought it might be something with the control cable or the control lever itself but when i disconnect the throttle cable from the motor i can't open the throttle manually on the motor either. When you try it in normal operation shifting it into gear first it will throttle up fine. Hope i don't sound like im rambling but im not real sure how best to describe this. Any help is appreciated. I have come quite familiar with the Control itself and have had it apart and greased up and everything. Both cables operate smoothly as well.
