86 18' Starcraft SFM
Status
Not open for further replies.
MD28
I also filled the rivet countersinks with durhams rock hard water putty. That name is no joke. sanding that down is rather difficult. It was very effective however. I then added a final coat of spar to the deck. Next I really need to bite the bullet and buy some vinyl for the deck.
MD28
I also repaired the gunnels. They where full of holes from who knows what. a mix of rod holders and Bimini snaps I guess. I jb welded with the putty variety first making a kind of epoxy rivet. Then I used the liquid variety to smooth it out. This involved much sanding efforts as well.
y4mrEl5og81C9tDm7VtyL3GQUjyoXeMcHBLKEwbYtz0RYLo0ut-Ewlv6xDPUS3F6mvNo4KmLmXyZOsWieiGkh5r3hxVb9iAurs9TYBmJ3vRZ_pnWkJLnnn7yjhrgriC66ctSrVm3ZhGJ8CnJarfmU5F_WkNBsvbf5AOlWZFAeJns0yswgVUxV6Ud2CxsIe7fihwCUkcU-Ejshesdwt8VgdEJg
y4mHo9lwgOo3hPAYUReorZ2Wjq-zC3oY_A_99lluFpR4gWgG9AM76LLeZIcJB-zjOpqXhFR1aUGNy4eDr5hfUF_qpsCmQ3XJzaWMyNKSrr2Hslmr3vXVGMFhgAUwupJDB_xeHNen4tWnNRBFFG1KpP3HXE_qEocdm3PnMUgg3BE-Sg_dy4DyI0FLsb03ZySXOYEEaelQ-umppxDR5iTnLvgvQ
y4mpmwzGEmSKICLgtAFBgRGkNeRAuPw2Fbml_i3_hnsJtqApAPAzb4TqQLMQc625ZdLn2Fd3qWZbZR_C5ZcsHHV9COVKR4I70ycgb12NkIwqE56b_2KXONwu32PYF1PsDFF99RbhpmfWf9aLx7hDggK0o0zgszz9XCBsLJQ1RtTOgbwYGuPQ5DUO53DBsaJdjiAiLM7NmHa5KUQmdpczd6V7w
y4m5EkwA91Hs9q1-X6gEMeY0CV880K8PRDJ8mKS2vI06RIY683RBR9YLtI_pCOS9sIDTPEnB9dVshrGDHOz6_fW8vezpNuti4Cvi_7IiB3AQ-13uvLAIg6wMGM1dK37iKKXn0VRq9B0TTgaBsucufHQeqpkID2q3nd5ubL9sZBlrUZGZBCyO--POPgb0oIlhyJlq-Qh6I83xdvWP_TvJD4Ozg
sorry the pics are smaller than normal.
Watermann
Looking good on the repairs and the motor will be looking new again once the decals go on. :thumb:
MD28
What size aluminum angle would you experts use on the back casting platform. I was thinking 1/8 thick would do.
Watermann
Checking out others builds will yield a ton of ideas and information on not only casting decks but everything else. I used 2" x 1.8" angle AL for my casting decks.
y4mHB0u7qY7jQXuo_D6Ig6q_7tuGiichsnqVog6rfcXnUowkhOn656OzcQ9IiCinUzy4fqnav4TZR2-Sd3uGlWuRnCvgeqlXAcaCY2HmUu4g1vctx8Jh9v_RJvZBiJ2UJm0fNsvMiJ6iFcn90L4E0Q_78iVSKolaBN7pnRN9MQEzYD-hz7Xv-Ek6g8P_og79ghl37qJZ3MKRKyrLaTAzKDxuA
MD28
Thanks Dutch. I was searching your thread again but couldn?t find what I was looking for. I?m glad you had a good time on the boat this summer and success hunting. How did you like that casting platform on the back?
MD28
I hear you there Waterman, I just can?t find the thread page and post that I?m thinking of usually. I think I have stalked a few threads here enough to put me on some government watch list.
Watermann
I hear you there Waterman, I just can’t find the thread page and post that I’m thinking of usually. I think I have stalked a few threads here enough to put me on some government watch list.
:lol: yeah I've read plenty too, even some glasser threads (don't tell anyone) :rolleyes:
MD28
Nautolex vinyl floor has been installed.
s!ArpoGezjPJjLiU4HMgFONIjZoW4Q
y4mM9g_RR-jTUV4zNzgjC-EEzyBDzfO4PbfCHLMpc1EYncmU3kY_H-ikJPROjnfcAGOyKBtYJfKLQEz1P7UnBDgCCZsTJdL3ev-GQlQaBYrZsQ5dbPZt95LNVfuQE0nU4J0k8hXbNcJfPqkX6wdQBxm3bQv0bvD3M7GupF_w3aum1VAyWuY9oRll5lDQsLryeq7ZUA4T2Nwom-kYzGI0T1w5w
Cut the holes and installed the hatches so I dont step in them anymore and the livewell and plumbing is in place.
y4mp5GypdfQ6R9ANZXkjpVGlY4j4f45YKFE-212UbzHR6r_gl8WjudSJSFSx4R4ESaHf7v7TSfLyFF7Z4CClx1wq0N8oT3n646N82RyDgn-fQOwhfeOeiJYhhS_ghJPbYMmY5BczvLKVWsT02tvHy2O-N_mQGDg8kFxoOt0pdnuO4p3jHplPVWPl7oppZ_pfzK8OYHfy69SU0_YUVfH7_ccCA
y4m5D50tqdlUrRmLpLa3yx_3GCyBu9W1ZRh1QdWKaMbXpfSZ6M-YzWxX8wR5EMHw8eaMKg3MW-V6tZ30SrtMMPBkXGFBRPEPijxGyLKsGIYgCQEDgbxhvVnaDcfpw2Cw8-Clq-ppGVqUCSaq7hXf0yLxr74Tvg3S6-hlpbHKzEOYl97CrrKdrW__jgYPyZ1j3q0y14ad3dFF9cc9Lsm4oz_bQ
y4mroAH0_Q6KcJqAiNXkNlr6dcyy-GEhZC2qIq7Ps9L88jiNpnmK1VBfIZquE8XCQUtc13WFdtL1aONkKKvUKKvuIYYLYDFZdrCz1d2F27i2B0524V5PAVM39oIDy0s0piC9BIeWQn4dLnVNDOnHKIVFg3C5aXkpGPaAUG1TVDtB-cIJoEqSQeSsEF2o8l14Br6dhzy1t4S7FLxnIBtgd_KIA
Candutch
Thanks Dutch. I was searching your thread again but couldn’t find what I was looking for. I’m glad you had a good time on the boat this summer and success hunting. How did you like that casting platform on the back?
The rear deck was fantastic, so very glad I took the time to put it in. I think I have fixed my pic links on my thread now so you should be able to find the front and rear deck builds.
MD28
Small progress with the cold weather and the usual business of life. I have the bow reinforced with multiple layers of 1/4 ply. I would like to add a trolling motor so I wanted something to bolt it to with some meat to it. The original is just the layer of aluminum supported by three strips of 3/4 ply. This I think will be better. I also am starting on the back deck. I plan on using the original splashwell by cutting it down where it plains out with the new level of the rear deck.
y4ml8Yp6_55K4HZN7iWZsiHxT2RHZlrYKfdWQ7plV9xndfxrb4aH8yWE9PGg_woV7LDOwrVTmKgvEVEItpclEcgxgMt_6QucQ7zXNlUrMeDW6Wax9W4eczVR819PuOflcYVbAdxt2EOasvx7QKWPDK-r_iZsCF2PEe8Tj6-MfrQzWnLur16UxK3_xk2NNs9WwtEUnpVwy-nKr-oKOv7xN5K1Q
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
y4m--QTzHTMeKa-9mR_-49w13qcrK467niPvGOOHPLA4XNOiGOGjAb25ysAZTskv3tHou9drIyMpCixiznP9w-syse_OJ7BzBoZr3NBjEk93BcAINJtxEJhlColtKL8jT_By9RH_STLZGFd5j_QOzenaOJ04939vCh_A26f-0O0HKiw8T-MZceK4AgXWbOES3l4X36pPu4Pc2R4QM43hZzkoQ
y4m7US9t9AQdym0vQa0rw1GohFnQvb2G4Su5RsHPlGf73QOSVauZYl3yHKHN0wxittPKPulbvu92QpdATv30B5uNyGpyPcS82J8mHID1VQJ9qOz7ujsryPoBmLBYYYEk5O0lfbnIEw65JSlKw3xigNyoJSYjRDEdAlZ6xmsiXD4i1erOuS2w9qyFeJX58Vmxmrxms0gkPgtJQXdtlOV0Bnapw
Watermann
The key to getting across the finish line is to have forward progress no matter how small, it all adds up. I too reinforced my bow deck for the big TM, I used 3/4" ply.
MD28
I didn’t think I’d get the curve with the 3/4 ply so I did 3 layers of 1/4. One solid layer of 3/4 would be stronger I must admit, but this should do me thinks.
knezzer
I like the idea of the bow support for the tm. I did the same thing for my little fishing boat and it made a big difference. Curious to see your splashwell come together, seems like a cool idea
nrf414
Definitely support needed under bow for bow mount trolling motor. I put 71# thrust and also reinforced with ply last summer. Worked well.
MD28
Are my pictures sideways for you guys? I have them sideways at times on my laptop and upright otherwise on my iPhone. I’ve tried rotating them when they do that before I upload and then they just post sideways again. I’d hate for anyone to throw out their neck snapping their head 90 degrees to look at my less than handy-work.
Status
