86 Force 125HP propeller question
fmt2bx
Here is the prop mounted on the engine:
I got this 15 inch pitch prop advertise for force engine but it looks very different
Rear view:
Front view:
Am i missing something or is this prop for a different motor?
Thanks
tommarvin
Ensign
Our 125hp parts catalog says it's part # PS 524
It's had to tell being black, ours is white aluminum.
We have a spacer part # 523099-1 and a cone shaped part #523094-2 called a propeller nut
iwaterdave
Put it on and see how it fits. sometimes they look different but fit just fine especially if different pitch.
SkiDad
that prop is correct - make sure you use the thrust washer mentioned above - 523099-1
after the prop you need the plastic flare spacer/diffuser - F532299
jerryjerry05
Older style prop.
​You need the hardware that skidad posted.
Do YOU need a 15?? The pic in your signature shows a boat that probably needs a 17 maybe a 19
fmt2bx
see my pic
Great thanks.
fmt2bx
Thanks
