86 Sea Ray Restoration [Splashed Oct 2017]
JASinIL2006
Re: 86 Sea Ray Restoration
Making good progress! Although I found the grinding to be the most unpleasant part of my project, The most nerve-wracking part was going at my boat with a Sawzall and a circular saw. Looks like you're diving right in!
Love your updates and kudos to your photographer! Great pictures of you working!
Jim
Goldie627
jbcurt00 - Yup, full steam ahead!
JASinIL2006 - Thanks Jim, Yea I was a nervous wreck till I figured out to saws-all two inches from the hull first, then trench out the foam, then curve your saws-all blade, this allows you to see what your doing, with this method you can practically lay the blade on the hull getting nice and close. I discovered this method by accident! lol
Sequence 01.Still001.jpgSequence 01.Still002.jpgSequence 01.Still003.jpgSequence 01.Still004.jpg
86 Sea Ray Restoration Day 7 Clip 1 Helpful Tools for Boat Restoration
86 Sea Ray Restoration Day 7 Clip 2 Upper Deck Bow Demolition Continues
Trooper82
Demo is going great! Wish I could work that fast...vids are nice...
Jayboat66
You are doing great job, when you finished the project your boat is going to be like new. I will say better than was made originally.
Goldie627
Trooper82 - I wish I could work that fast too! lol I'm glad you like the vids, I'm just trying to give back to this awesome community...
Jayboat66 - Thanks Jay, I hope so, we'll see when glass time rolls around :)
Sequence 01.Still002.jpgSequence 01.Still003.jpgSequence 01.Still0027.jpgSequence 01.Still00100.jpg
86 Sea Ray Restoration Day 8 Clip 1 Rain Is Coming
86 Sea Ray Restoration Day 8 Clip 2 No Building Permit
86 Sea Ray Restoration Day 8 Clip 3 Side Panels Removed
86 Sea Ray Restoration Day 8 Clip 4 Rear Panel and Battery Box Removal
Georgesalmon
I think my favorite part so far is the awesome broom repair. Really quick thinking in the face of an impending disaster, LOL.
Keep em coming, Enjoy these videos with my morning coffee. Your doing a great job. I might suggest you get all the wiring and such out of your way. It's just gonna be in the way the whole time, and there is always a chance of damage. With all your pictures and by marking the ends it would be a snap to put it back in correctly when the time comes. Keep up the good work.
Jayboat66
Georgesalmon is right, take the wire harness out of your way the fiberglass dust and resin can get into the terminals or connector and will be a nightmare for you when you try to start the engine. Avoid false ground, clean the connector before you plug them in.
I am thinking to do the same you did to cover my boat in the winter to avoid snow accumulation on top.
tpenfield
Looking good :thumb:
I need to catch up on the videos, but I did get a laugh from the "building permit" comment. Rain certainly is a pain when trying to do a restoration or repair, because you need things to stay dry. Your tarp structure looks good . . . you may want to keep it in the taller 'mode' as it may tend to shed water better.
Goldie627
Georgesalmon - That is so funny, I was thinking the same things about the broom and the wiring :) I am so happy you are enjoying the vids! My buddy Scott is the executive lead mechanic in the restoration :) We talked about the wiring. In an upcoming video you will see the wiring harness blown out and covered with a zip baggy. Also, all the wires will be unscrewed and situated neatly for complete access to the transom area. Thanks for the tips.
Jayboat66 - You will not be disappointed with the 1/2 inch pvc. It's light, strong, convenient, effective and inexpensive. Thanks for the wiring tips.
tpenfield - Welcome back to the thread. Yea, Scott is a comedian! :)
86 Sea Ray Restoration Day 9 Clip 1 Ice Chest Removal
ShellBack89
Nice work. I remember those days well. Took me two years before I even wanted to put back on a respirator or tyvex suit. Keep up the good work. It will pay off come spring!
Goldie627
ShellBack89 - Thank you for your kind words of encouragement, I'm anticipating spring like a kid anticipates Christmas!
Ten hour shifts this week at work so no boat till this weekend :(
I need some advise... I will soon be taking out the rear stringers where they attach to the transom. If the transom turns out to be good, how do I prep the bottom of the transom to tie in to the new stringers? Should I de-skin the transom bottom below the transom plate? or leave as much of the old glass on as I can? Any advise is welcome! I'm lost...
Sequence 01.Still002.jpgSequence 01.Still004.jpgSequence 01.Still0010.jpgSequence 01.Still001.jpg
86 Sea Ray Restoration Day 10 Clip 1 Gas Tank, Motor Mount and Starboard Side Stringer Removal
86 Sea Ray Restoration Day 10 Clip 2 Gas Tank, Motor Mount and Starboard Side Stringer Removal
tpenfield
Siphoning the gas out is always one of those preparation steps . . . I thought that you had already done it. When I did my 24 footer, it had a 94 gallon tank that had to come out. It was foamed in and took me about 2 weeks to get it out.
The rubber strips are used to keep the tank from direct contact with the hull. You should do some web searching on the various methods for fuel tank installation, as improper installation can cause problems and lead to failure of the tank and leaking gas. Basically the tank should not be in direct contact with the hull , nor the stringers, nor any bulkheads.
You can also to a pressure test of the tank to make sure it has no holes. pinholes, leaks, etc. The typical pressure test is about 3 psi (only) . . . so something like a bicycle air pump would be good. Don't use air from a compressor or anything like that, as it is too hard to regulate at low pressure, and the tank could pop like a balloon.
I'm currently doing a bulkhead replacement project on my 33 footer, and have been inspired by your videos. :thumb: So, I have done a similar thing to document the project.
As far as the transom . . . if it is good wood and good glass just leave it and grind the surface a bit where needed to rough it up a bit for good adhesion of additional layers of glass.
glnbnz
Hi Goldie I am signing on to watch your restro...the roll of Duck Tape I seen in your some of your pics means your serious LOL :)
Woodonglass
Goldie,
You MUST be an OKIE at Heart!!! Bermuda Shorts with LONG JOHNS!!!! My wife Calls me an OLD DUMB OKIE when I wear Sandals in the Snow!!!!! I LOVE IT!!!!! You are a Man after my HEART!!! Keep it up Brotha!!!!!
All you need is roughed up good pink glass, wipe down with acetone and stick on the new stuff. Make a nice round filleted joint so the 1708 will take the curve well and you'll be good to go. Hope for the Best, Plan for the Worst!!!!:D
zool
Hey Goldie, thanks for the entertaining vids man...fun stuff :)....Hoping to hop onboard to watch, Id help, but I have my hands full hehe.
I went thru that same ritual with the fuel lines being stuck on, finally got pissed and cut all mine off too!
Jayboat66
Wow! You just did the most difficult and hard job. Every thing else is easy. I like your videos. Keep the good work!!!
When I did my boat I had the help from my brother and my dad.
Goldie627
tpenfield - Thanks for the advise!
ShellBack89 - Thanks for the help :) I will be checking out your thread soon..
glnbnz - Welcome aboard! Yea man, duct tape is essential! :)
Woodonglass - LOL! yea man, you know you get to an age in life where you pretty much do what feels good and don't care much about what people think :) I'm just glad I'm not yet at that age where you would wear something like, sweat pants with church shoes! At that point your probably pretty much done talking to chics all together! LOL
zool - You're more than welcome to come along for the ride! In the words of Donkey..."We're off on a whirl-wind adventure!" :)
Jayboat66 - It's such a blessing to have family.... even more of a blessing when they are willing to help! Thanks for the encouragement we are moving along nicely.
Sequence 01.Still001.jpgSequence 01.Still003.jpgSequence 01.Still0011.jpgSequence 01.Still0022.jpg
86 Sea Ray Restoration Day 11 Clip 1 Project Update
86 Sea Ray Restoration Day 11 Clip 2 Transom Wire Removal
86 Sea Ray Restoration Day 11 Clip 3 Transom Wire Removal
86 Sea Ray Restoration Day 11 Clip 4 Port Side Stringers and Foam Removal
86 Sea Ray Restoration Day 11 Clip 5 Port Side Stringers and Foam Removal
86 Sea Ray Restoration Day 11 Clip 6 Port Side Stringers and Foam Removal
zool
Sounds like you guys were huffing some helium in clip 2 :D
Rolling right along tho......taking out all the wires back there may seem intimidating not knowing the where come from, but when you figure it all out in the end, you will know all of it inside and out.....I have no idea how to put my hydraulics back together......yet :)
Goldie627
Merry Christmas! And a Happy New Year to everyone!!
zool - Yea it does! :) but just trying to keep the vids as short as possible :)
