hey rick... this is that bait tray...
thanks chevy, im going to instal the new electronic ignition distributer in the next few days and then when its running recheck for my oil leak because ive resnugged the rocker arm cover after doing the new gasket...Looking good there. I remember back when this all started for me. Watching your chipmonk demolition videos. Hope you get your motor sorted out.
That looks pretty cool, but how do you plan to get the water out of it? After the ice melts, I mean.
Thanks jas, the more I looked at it the more I didn't like it so I got some white acrylic plastics, I'm gonna glue them then put a beed of silicone in all the corners and where pieces meet together (seems)
For getting out melted ice I ordered a 12v dc aquarium water pump, so on the way back to the doc I can pump out any water then just wipe the bottom with a towel
When the pump gets here I'll look at the hose sizes, I could put a passthrough fitting to an elbow from the bottom then run that line to the water pump and out the back of the boat
I prefer not to have it go into the bilge
I was thinking.... what if you did half seat half cutting board or 2thirds seat 1 theirs cutting board? Or make the cutting board removable so you can keep the top of the doghouse paddedNuthin like the smell of sliced squid and sardines. I've been thinking about making the entire top of my doghouse into a 3 inch thick tackle box with a nylon cutting board for a top. Only problem I see is I like the padded top to sit on when trolling. I tried connecting the steering of my kicker to my outdrive, but I don't sit up front when trolling.
you could also use a flush mount rod holder, use a rod holder extension, then put a mounting bracket, from there you could build anything to screw to it. I'm at work but when I him to the boat 2maro I'll take some pics to kinda give you an idea.... as handy as you are you might do the whole thing from scratch.... I can see it in my head it's kinda hard to explain, ill just take some picks
