86 Smoker Craft Challenger floor replace
Gold Eagle Co
iboats Partner
Speaking from experience, this stuff REALLY WORKS great on cleaning vinyl.
303 Vinyl Cleaner. A Bit Pricey but...Worth it cuz it WORKS!!!! It'll makes those chairs look NEW!!!!
[FONT=&quot]Thank you for the recommendation and sharing your experience using our product! We appreciate loyal customers like yourself! Just wanted to let you know, the label on the bottle you currently have has been updated and if you are interested in purchasing more, you will want to look for the 303? Marine Multi-Surface Cleaner. Also, below is a link if you interested in purchasing this product from iboats.[/FONT]
[FONT=&quot]Have a great day![/FONT]
Bow Guy
How do I sign up for free samples?
TruckDrivingFool
I wondered the same thing, link says expired registration, maybe it's a past deal and someone forgot to change/remove the link in the signature.
jbcurt00
PM Eagle and ask about the samples. IIRC, they sent some out several months ago. No idea if it's still active.
Anybody else interested should also PM Eagle, rather then posting here in BowTie's topic
Bow Guy
Made some back cushions today..... I think I'm getting carried away!
the 3M eraser works great on the stripes picturers when I done... definitely want to do it outdoors.
Bow Guy
So I'm tracing the wiring on the Smoker to day and testing it with my jumper box. Bow light works after replacing bulb.. check! Anchor light works... check!! Bilge pump works... Ckeck!! Newly installed cabin lights work.. Check!! Now i hook everything up to the ground buss bar and New switch panel and NOTHING!! So I'm setting there.. like what the #%*%#!!! Then I realize.. check for fuses in the new switch panel dummy!! Daaaaaa! lol Everything works great!!!!!
Next install Gas tank all cleaned inside,checked gauge float and it works...
Any Ideas how to test fuel gauge on dash to see if it works?? I have a FLUKE Meter
Bow Guy
Well the Jury is out on the Sunbrella 303..... $16.50 down the drain! did absolutely nothing to what Kaboom already did for 3 bucks. So. as soon as I can I wll be sending for a refund..
Gold Eagle Co
iboats Partner
Thanks for the feedback! We are sorry to hear that our product did not meet your expectations. Since we usually do not get this type of concerns, we would love to hear from you to let us know what can be improved upon. Also, we definitely do honor our ?Satisfaction Guarantee?, so simply mail us a copy of the receipt and we will take care of it. Feel free to contact us anytime. Thanks again!
Bow Guy
Gas tank Installed Gas gauge and fish finder,compass all lights, bilge pump etc. working.... More pictures coming!
Watermann
Looks great and like you're about there, so powering up is next and then splash time?
Woodonglass
Ok, try this on those seats. Get some Toilet Bowl Cleaner and some Comet or Ajax Powder. Mix the two together and form a Paste. use a brush and brush on some vaseline on all the seams. (you don't want the paste to get to the thread cuz it will really harm it) Then brush on the paste all over the vinyl. When it dries spray it down with water to re-activate it and let it dry again. Spray it one more time and then use a stiff bristle brush to brush and clean it off. Do a final wipe down with the 303 and see what you get.;)
Bow Guy
Motor is on... Steering hooked up.. Controls hooked up... Fuel line hooked up... next Battery, add Fuel fill Barrel with water and test.. trip to DMV for New Registration and hopefully will make a splash next weekend..
Watermann
Looking good BG!
Hey the muffs work way better than trying to fill a barrel up with water and there's not the mess of slime from the 2 stroke oil.
Bow Guy
Update,,, the Motor started right up but no peeing... Pulled the lower unit and the Impeller was toast...Going to replace everything.. also the shifter cam was in 3 pieces .. Parts on order..Hopefully back together by next week... so in the meantime I finish removing the stripes and Smoker Craft logo..
